hi all ive just bought some nice but used mono m4's and need to change the rear hose as it is too short.
can someone tell me how to do it and what bits i need to order(hose etc)as i believe some bits are reuseable!
also where is best to get bits from (crc?)
thanks
steve
Are yours 5 mm or 6 mm hose? 6 mm is no longer available.
All you need is the hose if its 5 mm. If the existing one is 6 mm you need a length of 5 mm plus all the fittings
cheers tj!!
how would i tell if the hose was 6mm or 5mm??
the brakes are the newer silver coloured ones about 16 months old.
so i just need the hose and everything else is reuseable??
cheers
steve
Measure the hose.
I have only had the 6 mm ones apart but I think the 5 mm is the same - sleeve nut, union and olive all reusable.
http://www.hopegb.com/page_mep_force_36.html
Measure it you fool. ๐
it'll be 5mm though.
Renton you have email
