I cant get my new headset right - even when the top cap is screwed down and the fork is jammed tight, it wiggles. The bottom by the crown race seems OK.
Isn't there supposed to be a wedge ring under the top ring of the headset that wedges between the steerer and top bearing?
I haven't round one in the box ๐
How much gap have you got between the top of the steerer & the top of the stem?
What headset is it?
FSA headsets have one of those compression rings that tightens it up
How much gap
none
FSA headsets
yes its an FSA. What do I do with it?
buzz-lightyear - MemberHow much gap
none
Well that's the first thing you need to sort out ๐
usually is a wedge shape ring that sits between the steerer tube and the bearing, although they may well make headsets without?
check the bearing rings are up the right way?
"gap"
Oh sorry I misunderstood. I've 3 spacers under the stem so that the stem is proud of the steerer-top by a couple mm. I tighten the top cap and it presses the headset cover into the top of the frame - it doesnt seem to be pre-loading the top bearing.
"usually is a wedge shape ring"
yes that was what I expected but there isnt one so I dont understand how the bearing is going to get loaded . The bike shop bashed the cups in but I wonder if they lost the wedge?
I'm curious about his "compression ring" remark what are they then?
FSA have pdf files on their site (IIRC) can you compare your parts with how it should look?
a couple of mm may not be enough - 5mm is a safe option
right: i;ve looked at the tech sheet and every model has a wedgy ring to load the bearing. So I guess the bike shop lost mine gggrrrrrrrr
Of to the shop tomorrow lunchtime
ta everyone
Problem caused and solved by Halfords - they lost the wedge ring when they fitted the cups. So they robbed another set off the shelf for me.
The rest of the build is done (preliminary). Hope to test it Sunday and post pics.
thanks for your help chaps
I bet they then try and sell the next one without the wedgy thing ! I was in there the other day and they tried to sell me a seatpost without the top bit that goes over the seatrails if you know what I mean. "Oh no", they said, "you don't need one of them with this sort of seatpost". When I demonstrated what would happen they just took it and put it back on the shelf......
I am still giggling from that one.
Why, oh why does anyone ever buy anything from Halfords ? They aren't even cheap !
At least they do sponsor cycling, so thats something.
Halfords - theres the problem right there. You want something done right, do it yourself.
๐ฏ
