Help fox service
[Closed] Help fox service
just servicing my fox forks alls going well until i come to put the 10mm bolt on the bottom onf the damper leg. the screw goes on but afer about 3 turns nut at the bottom of the damper rod starts turning as well. How can i stop the damper rod from turning
Posted : 14/01/2012 4:14 pm
 Taff
If you take the forks apart can you screw it in ok ie not cross threaded
Posted : 14/01/2012 4:22 pm
