Hi,
I have the above and the blue compression / lockout lever has worked loose. It remains on the fork crown owing to the retaining screw holding the rebound dial in place but as it's loose the lockout doesn't engage properly.
I've undone the retainer screw and disassembled the lockout, rebound and compression dial to see what's lurking beneath and found one ball bearing and that's it. No springs etc.
From the MOJO site... http://www.mojostore.co.uk/acatalog/Adjusters_and_Small_Parts.html ...it looks like the bearings are sold in 3's and I may be missing two. Does anyone know if that's the case and am I missing more than just the ball bearings? Also do these ball bearings slot into the three holes on the topside of the lockout lever? Any advice would be greatly appreciated.
Cheers,
Ed
The lock dial had 3 small allen grub screws in that hold the bearing in place to lock against the shaft of the top cap damper
