I've lost the little black cone shaped bit of plastic which goes into the non disc side of the hub, where can I find them online to buy?
Tis very annoying.
Ta.
Tim
bump
bump ouch!
Which hub? there are several of 20mm models in the XT range, you need the M### number. When you have that...
Go to the [url= http://techdocs.shimano.com/techdocs/blevel.jsp;jsessionid=3xKJRKPT3qRVYTnf7rT0FvpNqGWpGM4t9G2VXmGn2wZ8422l9lGQ!-1214546971?ASSORTMENT%3C%3East_id=1408474395181679&FOLDER%3C%3Efolder_id=2534374302051947&bmUID=jZZ_IDT ]techdocs[/url] and find the EV for your hub, find the part number from the EV, an either Google the part #, or take to a LBS, and get them to order.
There was only one 20mm XT hub, it was the HB-M776. There was also a factory wheel in 20mm, the WH-M776.
So have a look at these exploded diagrams and see if you can spot the part you need. Although I have a feeling you are talking about a part that comes with the skewer rather than the hub. The skewers are fork specific so you may be looking for a Rockshox or whatever spare rather than a Shimano.
[url= http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/HB/EV-HB-M776-2703B_v1_m56577569830677325.pdf ]Hub diagram[/url]
[url= http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/WH/EV-WH-M776-F-2713B_v1_m56577569830728617.pdf ]Wheel diagram[/url]
Aha, fork specific, thanks, that's probably what i'm after, had no luck with the Shimano tech documents.
Ta muchly.
