Right, I have a hope mini, but there is no fluid in it.
Is the the process the same as normal bleeding as i have done this before , or is there anything different I should be doing ?
Cheers.
Posted : 02/06/2010 5:34 pm
No, just fill it up. Give the caliper a damn good tapping to make sure no air gets trapped in there.
Fill it slowly, and squeeze the lever slowly, less chance of trapped air.
Posted : 02/06/2010 5:35 pm
keep an eye on the level in the resevoir as you pump as if it's runs dry you'll have to start again, should take about 4 resevoir fills to fill the caliper and hose.
Posted : 02/06/2010 6:14 pm
wind the reach adjuster out do you get more fluid movement per pull on the lever.
Posted : 02/06/2010 6:45 pm
cheers guys ,
Posted : 02/06/2010 10:35 pm
