HELP! bike squeak a...
[Closed] HELP! bike squeak and I cant find it
[#4914041]
Ok I have a 2004 sworks enduro and recently it has started squeaking and its really friggin annoying. So heres the deal... noise is coming from somwhere down near the bb, the noise is only during pedalling but only when seated?? When I stand up to pedal there is no noise! Ive tried removing the bb and checking it over and its fine no problems with that. I even wrapped the threads in plumbers tape to help seat it.
Noise isnt constant and is less serious when the bike is clean...any ideas??? Its driving me mad
Posted : 27/02/2013 10:23 pm
The seat?
Posted : 27/02/2013 10:24 pm
ear plugs.
After that
Saddle
Rear bearings
the bearings in the stays
cracked and creaking chain stays
Cranks
Shock Bushings
pedals
seat post/clamp
anything that moves.
I went looking for a squeak on my heckler yesterday ended by finding a collapsed bearing.
Posted : 27/02/2013 10:26 pm
I'd say its the seat rails too.. Or the union between the actual seat and the rails. Perhaps they are worn out.
Seat rails, seat post, seat qr. Also check the welds carefully around the seat tube. My 2003 enduro cracked at the tt / seat tube weld. My 2004 enduro pro replacement is still going strong.
Posted : 27/02/2013 10:42 pm
Mmhh saddle is brand new so dont think its worn out rails I might try dropping it off and try re fitting it. I was kinda thinking bearing or the main pivot by the bb
Posted : 27/02/2013 10:45 pm
Seat post moving in the frame and wee bits of dirt moving between post and frame.
Posted : 27/02/2013 11:03 pm
what bryan says. that is your starter for 10. crap gets cown the seat tube and it starts to creak. remove post, get a long bottle brushwith degreaser on it turn the bike upside down or at least enough to let any crap drain out and scrub down the seat tube. clean the post and smear a bit o grease down the seat tube. insert post and see if its still doing it. then try post/saddle interface. they are the easiest ones to start with.
Posted : 27/02/2013 11:11 pm
sometimes I end up riding around the street with gt85 in my hand giving one bit at a time a squirt until it goes. hope it is pedals/saddle and not a weld failure.
Posted : 27/02/2013 11:36 pm
If it stops when you stand up its likely to be seat related.
Posted : 28/02/2013 11:42 am
