Heli taping, Bury/R...
Heli taping, Bury/Rochdale/Oldham
6 Users
Looking for someone to apply some heli tape to my wife’s (low spec Spesh hybrid) bike - would rather not do it myself as it will look shit (given that I have as much talent for anything DIY as a pig has for roller skating).
Used to be something the LBS could do, but all the options seem to involve £200 laser cut wrapping, where really all I want is the top tube/down tube/chainstays/seatstays having a bit of neat tape on.
Anyone have any recs?
Posted : 22/05/2023 2:46 pm
Theres Shak Wrap in Bury but I've no idea what the pricing is like.
Its easy enough to do yourself with the judicious use of a hairdyer
Posted : 22/05/2023 3:05 pm
There are quite a few generic frame protection kits now, which fall between DIY heli-taping and the full Invisiframe treatment.
One of my bikes came with an "All Mountain Style" one already fitted, and it's decent enough. DYED are the other big name I think.
Should be tidier than the home-cut helitape (that I fit badly to my bikes).
Posted : 22/05/2023 3:13 pm
Ridewrap also sell generic kits and come with everything you need to put them on. Open a beer and get cracking, be done in 6 hours 😉
Posted : 22/05/2023 3:27 pm
@binners Extortionate for what it is (£200 which is probably more than the bike is worth)
@tmays Yes, that’s what I’m afraid of.
Posted : 22/05/2023 3:45 pm
See that 6hrs isnt worth 200 quid...
A universal kit from invisframe is about 65 quid.
So its 140 quid extra for a bespoke kit fitted...
Sounds like you're after the moon on a stick
Posted : 22/05/2023 3:48 pm
For my Camino, I bought some protection tape from wolf-moon-uk on ebay.
It seems to be decent quality stuff - nice & thick & went on well.
I measured the frame, transferred the measurements to the tape & cut the pieces out. I then just added radiused corners, to prevent them snagging.
I heated the frame & the tape using a hair dryer, then used a sprayer with a very very dilute mix of shampoo & water which means you can shuffle the tape around a bit if you don't lay it quite right.
You can then squeegee it in place with an old credit card and your thumb. If the edges are a bit reluctant to stick, you just need to keep applying a bit of heat & pressing it down - once all the water has been evaporated it will stick nicely.
It's definitely a job to take a bit of time over, but it's not difficult and quite enjoyable over an evening with a beer.
EDIT - It cost me £11.49 for 2mx50mm wide. They do several different length & width options.
Posted : 22/05/2023 3:57 pm
Sounds like you’re after the moon on a stick
Yes and no. What I'm definitely not after is a full laser cut vinyl wrap, which is what that £200 gets.
All I want is someone to apply some off the shelf heli tape to a frame… Last time I paid someone else to do this (granted a couple years ago) it was £50, which even if it's gone up a bit seems fine.
Posted : 22/05/2023 4:46 pm
If it's a cheap bike. Or ask invisframe to send you a blank square and do it yourself.
Or my only other idea see if any local car wrapping place's do it
Posted : 22/05/2023 5:45 pm
