headset with stack ...
[Closed] headset with stack height less than 22.5 mm ?
Hi all
i need a headset with a maximum stack height of 22.5mm
im a tad confused with integrated ,semi and in line??
I have spotted crank brothers headsets at 21mm but not very good reviews
http://www.chainreactioncycles.com/Models.aspx?ModelID=24985
can anyone point me in the direction of a good value standard 1.1/8 headset with a stack height of less than 22.5mm please 8)
Posted : 30/09/2010 12:20 am
I've been using the DH version of the Crank Brothers one since January, in all kinds of shite, it's been brilliant. The difference between buying a new set of forks and not.
Not sure what the differences between the different versions are as the DH must be the most over-built, but is tiny and weighs ****-all, very simple design, so I suspect they're all the same just different colours.
I did a lot of research, I don't think there is a lower stack height one anywhere, unless something has come out recently.
Posted : 30/09/2010 8:31 am
Paul thanks for the info
when i had a search on tinternet crank brothers were the only one below 22mm!
they have recieved some crap reviews though !
Posted : 30/09/2010 2:39 pm
