Headset / stem help...
[Closed] Headset / stem help please!
I have genuinely tried, but woah are headsets a bit confusing to the uninitiated!
I'm doing a bike build with the kid (you may have seen some of my other threads) and am now looking for a bit of advice on the headset.
The frame is a Brand-X HT-01 Hardtail MTB Frame (27.5") [ https://www.chainreactioncycles.com/brand-x-ht-01-hardtail-mtb-frame-27-5-2019/rp-prod130452 ].
I have a tapered 27.5 Rockshox Revalation fork to go with it. The only slight wrinkle is that the steerer is shorter than I realised at 15cm. I don't have a headset yet and I have an older Brand X stem kicking about but on trying that and holding it up to the frame, I think it is going to be a tight (but I think it will be ok with the right parts) fit.
From my research, I understand that I need a ZS44/28.6 top and ZS56/40 bottom (semi-intergrated/zs/whatever else it is called but non-integrated and non-traditional) headset. I'm read that Brand-X's own headset could work, but doesn't actually cover the headtube at the top well. I am looking for more budget friendly (in fact I'm already (£150 over budget - whoops), so would like to avoid going Hope and have seen FSA suggested - but it looks like it has a profile that is quite high and that concerns me given the steerer I have available.
Searching I think shows Cane Creek, Nukeproof and Superstars as options (the last two are less over my budget!).
Any suggestions for a recommended headset that has a narrow profile - I'm wondering if the Superstars one could be ok??
And what else might I need, do these come with crown races etc?
And if I need to get a shorter clamping stem - any ideas for budget friendly options?
Thanks for help in advance!
Posted : 24/06/2021 9:55 am
I'd just go superstar, £35, mine have all just worked, no problems, can get pretty colours too if that's your thing.
The cheaper fsa ones are probably for straight steerer and not zero stack.
Posted : 24/06/2021 3:05 pm
Superstar are pretty good IME.
in terms of stems, it depends on what length you're looking for.
long, something like a second hand bontrager, they have the bolts more central to the clamp, so you can get away with a slightly short steerer more so than the wide clamp stems. that or a thomson.
short, something like the Wake Am stems on ebay?
Posted : 24/06/2021 3:35 pm
Cheers, is superstar about as slim as I'm going to get then?
Posted : 24/06/2021 4:46 pm
ZS headset all have pretty low stack height.
I've got a Nukeproof Neutron. According to the drawing on the CRC website the bottom cup is 3mm and top cup is 8mm
Ragley Stubbing has always been my go to stem for a low stack height
Posted : 24/06/2021 5:00 pm
 a11y
I asked similar recently but haven't actually progressed with anything so far, but might help.
https://singletrackworld.com/forum/topic/low-stack-stems-current-options/
Posted : 24/06/2021 5:02 pm
https://singletrackworld.com/forum/topic/probably-a-stupid-headset-question/
Lots of useful information there
Posted : 24/06/2021 5:05 pm
I’ve got a Nukeproof Neutron. According to the drawing on the CRC website the bottom cup is 3mm and top cup is 8mm
Superstar website says:
Top Cups: ZS44 - Stack Height 7.5mm – Insertion 9mm
Bottom Cups: ZS56 - Stack Height 5.5mm – Insertion 9mm
And...Note that some manufacturers list cup only to make them appear shorter than they are. so I don't know if I can compare those directly to the Nukeproof ones?? But I guess we are only talking a few mm in any case.
I asked similar recently but haven’t actually progressed with anything so far, but might help.
Thanks - that was helpful!
Posted : 24/06/2021 5:57 pm
