Headset press (self...
[Closed] Headset press (self-made) I could borrow in Hebden
 Sven
Hi, as title really, is there anyone in Hebden Bridge or surroundings who would be happy to borrow their (self-made) headset press to me, and possibly a headset cup remover. I know both are not hard to assemble from simple bits from the hardware store, but I just need to press two headsets in this weekend, and hopefulle won't need the tool for another while.
Thanks, Sven
Posted : 11/09/2009 11:22 am
 nbt
If you're in Hebden Bridge, have the lads at the STW office not got the tools you require? It's only down the valley in Todmorden
Posted : 11/09/2009 11:30 am
why does it have to be home made?
Posted : 11/09/2009 11:34 am
 Sven
It certainly does not have to be a home-made one, I thouhgt my chances of finding a home-made one are higher, but if you have a 'professional' headset press happy to lend to me, I would take either.
STW is probably closed at the weekends, not sure whether they want to give out tools anyway. I just thought there must be a few cyclist in Hebden/Todmorden who have a headset press...
Thanks
Posted : 11/09/2009 11:41 am
I have one if it will wait until Mon, im in Luddenden Foot but workimg till 1pm then away for the weekend.
EDIT although the parts from CVS or Bonsalls might be cheaper than the customary 4 pack hire charge ๐Ÿ˜‰
Posted : 11/09/2009 11:45 am
I don't think anyone's around this weekend, but if you're around before we all go home tonight, or on Monday, then you might as well bring your bike round and we can do it while you wait. It'll only cost you some Jaffa Cakes.
Posted : 11/09/2009 11:51 am
Did mine in a vice last week. Piece of pi$$ to do.
Posted : 11/09/2009 11:53 am
[b] to borrow[/b] ............. [b]to me[/b],
You could lend mine if you want.
Posted : 11/09/2009 12:16 pm
I've used two blocks of wood and a club hammer. I've done this twice now.
Sounds brutal and clumsy, but it actually works like a charm.
You need an assistant to hold the frame, and something solid (concrete) as a base. If you use something flimsy then it doesn't work nearly as well.
Your assistant holds the frame. Put the blocks of wood in the obvious places. Hit with hammer reasonably hard (but you don't need to go mad). Check by eye that the headset is aligned (it won't be to start out). Adjust next hammer blow accordingly. Repeat until headset is inserted.
Posted : 11/09/2009 12:28 pm
 Sven
Wow, a reply form Chipps himself, thanks for the offer, as much as I would like to come along at some point, I suppose I am not around while you are at work and vice versa. Thanks anyway.
nigew: Thanks for that, I'll contact you on Monday if I haven't sorted it by then. CVS didn't even have threaded rods last weekend, I haven't come across Bonsalls as yet...
I sent an eMail to you, ChatsworthMusters, thanks!
I used a hammer and wood in the past, too, but now splashed out on a Hope headset, so I wanted to go the safer way, and most of my tools, incl. vice, are still in storage in Northumberland, so can't get them any time soon....
Posted : 11/09/2009 1:22 pm
