Headset help needed
[Closed] Headset help needed
My 2010 Marin, according to the spec sheet, has the following headset.
FSA ZST No.10, Internal Headset Steel Cup Plastic Top Cover, Black, 1 1/8" Threadless
It isnt in the best of health, so if I was to replace, is it possible to get something better ? Ive tried google, forum searches etc but it all gets very confusing, some describing these headsets as semi integrated and very frame specific etc...
I want a better part if im replacing it, so what would fit ? If I was looking at Cane Creek or Hope, which ones would I need ?
over to the STW knowledge base !
H
Posted : 18/10/2012 12:35 pm
Stem has stack height of 40mm if that also helps. Two spacers under it which places stem at the top of steerer with no steerer overlap above the stem.
Posted : 18/10/2012 12:40 pm
Try this?
http://www.canecreek.com/headset-fit-finder
I used some info off Cane Creek's site to find mine. V helpful.
Posted : 18/10/2012 12:41 pm
[url= http://www.canecreek.com/tech-center/headsets/shis ]This[/url] is what I used, but if your bike's in the headset fit finder, you're sorted 🙂
Posted : 18/10/2012 12:44 pm
PS. If it works, that'll be £15 please.
No free favours on STW.
Posted : 18/10/2012 12:48 pm
Going by the description the ZST is normally for zerostack/semi intigrated. Hope call this an Integral headset and from the pick and mix headsets it is a 2-top cup and B-bottom cup.
There is this FSA on that is pretty good, mine lasted 2 years abuse with no maintneance before i needed to change the bearings (these can be bought seperately) I bought a new headset before realising about the bearings and then sold it on to philconciquence from here as i changed my forks and needed a headset for them.
http://www.chainreactioncycles.com/Models.aspx?ModelID=51070
The hope one as an all in one
http://www.chainreactioncycles.com/Models.aspx?ModelID=18084
however i think the pick and mix works out cheaper, especially here
http://www.merlincycles.com/bike-shop/mtb-parts/mtb-accessories/headsets-1/hope-pick-n-mix-headset-cups.html
HTH
Rusty
Posted : 18/10/2012 1:25 pm
Cheers all....been at work hence slow reply...u can tell I don't work in IT.
Posted : 18/10/2012 4:14 pm
you get a head doctor with the complete one hence the extra.
Posted : 18/10/2012 5:32 pm
