Hayes Stroker Carbo...
[Closed] Hayes Stroker Carbon Brakes - worth reviving? Can they even be saved??
I have an old pair of Hayes Stroker Carbon disc brakes in the garage that haven't been used in over 5 years, they were just sat on a bike that never got ridden.
I'm now thinking of getting said bike rolling again but the brakes feel like they're full of syrup rather than DOT5.1. Is it likely a good bleed will sort this out or am I looking at a full strip down & replacing all the seals, etc?
Or are they beyond help?
Posted : 29/01/2019 4:05 pm
Try bleeding them and see how they are before you start spending money on them.
Posted : 30/01/2019 12:03 am
 JAG
I'd bleed them and see what happens.
Brake fluid doesn't damage the seals in brakes - the seals and the fluid are designed to be together with no degradation over time other than water absorption. Not that that's an issue for brakes on a mountain bike 🙂
Posted : 30/01/2019 9:28 am
I’ve had a few sets of Strokers. The levers di seem to lose their springiness but I’ve still got a set on my station bike that have been doing daily service like this for years. If you’re after premium performance I’d get new brakes; if you just need something to stop your bike then I reckon they’ll be worth a bleed.
Posted : 30/01/2019 9:41 am
My old Strokers get stiff levers if I leave the bike sitting for any length of time (its a backup bike so that could be months), they free up with vigorous pumping and then work fine, I think it's the seals getting a bit stiff and sticky.
Posted : 30/01/2019 10:09 am
Cheers folks, I think I'll give 'em a bleed then, see how it goes.
If that doesn't work it's go great loss really as I've found a couple of cheap replacements.
Thanks.
Posted : 30/01/2019 5:39 pm
