If so, any chance you could report back with the external diameters of the top and down tubes? Much obliged.
2009 Trucker - top tube and down tube both 32mm ext.
Thanks
Actually, as the Trucker is an American design the diameter may be 31.8mm. Or 1 1/4 inches. My measuring tool isn't accurate to 10ths of a mm.
Cheers. Yes, it'll be 31.8, but the paint will make up the difference ๐
Didn't think Surly used paint that thick ๐
STW, the google for people who cant use google.
LHT.
TT=.8x.5x.8 at 31.8mm
DT=.9x.6x.9 at 31.8mm
ST= 1.2x.6x.9 at 29.8mm at the seat tube and 28.6mm at the bottom
bracket
Stays= .9mm
Fork blades= 1.1mm to 1.4mm tapered
Check.
Top Tube - 28.6mm dia 0.9 - 0.6 - 0.9mm thickness
Down Tube - 31.8mm dia 0.9 - 0.6 - 0.9mm thickness
Seat Tube - 29.8 dia at seat collar, 28.6mm dia at bb 1.2 - 0.6 -
0.9mm thickness
Stays - 0.9mm thickness
Fork - 1.2 - 0.9 - 0.7 thickness
Worth noting also the TT on the LHT is not a constant profile and is shaped at the ST and HT.
Cheers. Did try googling a couple of times but evidently made a hash of it. Got a link for those details? Might as well see if the Pacer's there too, save measuring my own ๐
