Have I knackered my...
Have I knackered my brake?
[#13535230]
I shall set the scene - SRAM Level rear brake, brake pads worn out.
Not able to push pistons back far enough using tyre lever method to fit new brake pads, so got a piston reset tool.
Use the piston reset tool, fit new pads, feel accomplished.
But then notice brake fluid dripping from reservoir on brake lever.... Arse.
So me resetting the pistons has forced fluid out - have I permanently knackered the reservoir /diaphragm?
Bike is only 2 years old and and this was only the 3rd set of pads. I had fiddled with lever reach/bite point - should I have reset that before trying to push the pistons back (I don't need to do that on my XT brakes)?
Posted : 20/04/2026 9:39 pm
No. Unlikely.
Someone will be along in a minute who knows the terminology but the reservoir can weep fluid when you force it back up like that.
It used to happen on my Shimano Xt sometimes when I'd bled them with worn pads then put new in and forced the pistons in.
They always were unaffected.
Posted : 20/04/2026 9:45 pm
I will need to do a brake bleed to replace the lost fluid, so I suppose if I can't get a solid lever and/or it pisses fluid everywhere then that will give the answer
Posted : 20/04/2026 9:54 pm
Should be fine and likely it is excess fluid if the pistons are now fully retracted but weren't previously.
How does the brake feel? If ok then it most likely is fine.
A bleed won't do it any harm, just make sure you get any air out.
Posted : 21/04/2026 3:36 am
Could just be excess fluid, especially as you are using a tool that possibly retracted the pistons further than when they were last bled, so that extra fluid has overflowed. All brakes are open systems I think, so technically the reservoir is not sealed.
 If the brake works, it’s not knackered.
Posted : 21/04/2026 6:27 am
nicko74 reacted
 K
You could just take the reservoir cap off and check the diaphragm isn't knackered and giving you peace of mind that they are ok, sounds like they need a bleed anyway.
Posted : 21/04/2026 6:49 am
Posted by: spooky_b329
the reservoir is sealed by the diaphragm.    fluid should not be able to escape at all.   either there was excess fluid above the diaphragm or the diaphragm leaked.
Posted : 21/04/2026 7:09 am
Brake still works, but lever feels spongy - which I had put down to the loss of fluid
Posted : 21/04/2026 7:20 am
low fluid does not cause it to be spongy.  Air has got in and not just in tbe resovoir but into the master cylinder and  / or lines
can you inspect the diaphragm ?   I'll bet its split.
a top up offluid and a rebleed might get it working again but if the diaphragm is leaking it will be vulnerable to air entry
the other possibility is master cylinder seals
i would try a rebleed but order a rebuild kit and do a rebuild asap even if a bleed gets it working
Posted : 21/04/2026 7:38 am
You can get spare diaphragms for Shimano levers for this reason - would be surprised if the same isn’t true for SRAM.
Posted : 21/04/2026 8:16 am
Was it coming out of a small hole on the level or coming out of seals around the plate at the bar side?
When I bleed my Codes I remove the lever syringe and pressurise the brake from the caliper end so I don't have to rush around getting the plug back in. I occasionally get a little bit of fluid come out of a small port near the hose at which point I stop. I assumed it was a relief valve of sorts, brake feels solid after bleeding and not had an issue with further leaks when cleaned up.
I do run my levers quite far into the bars but always wind them back out to the 75-80mm recommendation when bleeding.
Now all I need to do is get the pistons to move in unison and retract properly....
Posted : 21/04/2026 2:11 pm
You can get them for Sram levers, I have done in the past off Ebay. I did something similar to the OP to a Magura brake lever. My god they are cheaply made bits of tat... but the replacement diaphragm was also available to purchase (so I did and sold the brakes!)
Posted : 21/04/2026 2:13 pm
May have been AMAZON I got the spare Sram bits from
Posted : 21/04/2026 2:19 pm
Thank you for the link - have ordered it. I have had the cap off to look at the existing diaphragm and couldn't see anything obvious, but decided to fit a new one for piece of mind.
Posted : 21/04/2026 8:07 pm
