have I just buggere...
[Closed] have I just buggered up my new bottom bracket?
 Pook
Just fitted an HTII bottom bracket, just a basic shimano bb-51.
Fitted it as you do, drive side cup, then non-drive side. All fine so far. Used the old spacers to make sure it was all the right size and stuff.
Anyway, as I put the chainset through and gave it the tap, it popped out a plastic cap on the none drive side.
It's the bit that goes between the crank and the BB cup.
I can't get it back in.
Why has that popped out?
Have I broken it?
Posted : 19/10/2011 8:53 pm
Yes. ๐Ÿ™
Posted : 19/10/2011 8:56 pm
no you haven't, mine does that. bob in a cup of boiling water for a minute or so and push back in carefully. if you do break it i have a spare i can let you have on friday (coming into sheff)
Posted : 19/10/2011 9:01 pm
 Pook
Nice one.
I'll give that a go.
Posted : 19/10/2011 9:02 pm
pook mine popped out just the other day in the exact same situation. mine popped straight back on but i was advised the boiling water thing too.
Posted : 19/10/2011 9:05 pm
they are dead brittle plastic so be careful
Posted : 19/10/2011 9:06 pm
It's annoying when that happens, but it doesn't seem to actually do any harm if you just push it back in (not tried hot water though; that's a good idea).
Or maybe it kills it slowly, after about 5 months, in which case tomorrow it will stop working.
Posted : 19/10/2011 9:08 pm
Boil kettle, wait 30 secs, pour into cup or bowl, 30 secs till pliable, out, pop back in...job done.
Posted : 19/10/2011 9:49 pm
