Has my frame had it...
[Closed] Has my frame had it?
Ive managed to strip the threads on my frame where the Evo Link bolts on (trek fuel EX). Is there any chance of re-tapping the frame or is the frame doomed?
Posted : 25/07/2014 3:47 pm
retap or a helicoil might well be possible.
Posted : 25/07/2014 3:50 pm
How does a helicoil work? Heard of them but not seen one. Is it a DIY job ?
Posted : 25/07/2014 4:11 pm
on a frame and if you've not done it before I'd get a pro to do the job.
have a read/look here for details. [url= http://www.veryuseful.com/GM/tech/heliCoilInstall/Fix-A-ThredHowItWorks2.jp g" target="_blank">http://www.veryuseful.com/GM/tech/heliCoilInstall/Fix-A-ThredHowItWorks2.jp g"/> [/url]
Posted : 25/07/2014 4:13 pm
I'd be minded to try a repair on a DIY basis. Then you can at least say you did try to repair it when seeking authorisation to buy that nuke proof when it goes teets up.
Best regards
Posted : 25/07/2014 4:22 pm
Have a local workshop re thread it. I stripped the threads in a crank and they put a new thread in it. They basically filled the whole with molten metal, once it had solidified they drilled it out and put a new thread in it. Cost me a few quid, most impressed.
Posted : 25/07/2014 4:55 pm
@ rockhopper - Good idea, would be better though, if you tried to fix it and bodged it up, then I've got someone to blame...
Posted : 25/07/2014 5:03 pm
