Has anyone put a lo...
[Closed] Has anyone put a longer stroke shock on a Giant Reign?
I was thinking of replacing the rear float with a coil shock as I'm not bothered about weight and would like a more supple rear end on my 06 reign. Whilst doing that I thought I could change the stroke from 2" to 2.25". Will the rear wheel hit the frame on full compression?
Posted : 16/10/2009 11:03 am
Remove all the air from your air shock and see how close the rear wheel is then? I'd guess its going to be close. Unless you can get hold of a detailed axle path diagram for an '06 reign you'll never really know without fitting the bigger shock
Does the longer stroke shock have the same eye-to-eye length or not? If longer thenm it may be that it won't actually fit in the frame unloaded
Posted : 16/10/2009 11:06 am
 Olly
you could take the current can out all together.
measure the eye to eye on the frame at both full extension, and full compression, and compare it to a spec sheet for the shock your thinking of (if such a thing exists)
my trance does extend a bit further than the outer limits of the shock with the shock disconnected, but it bumps all the links on the frame, which cant be good?
i wouldnt have thought it was that brilliant an idea myself.
you could get someone to make you a custom top link, to extend the shock, which would probably give you a bit more travel too (along with ballsing up what a multimillion dollar bike company have deemed to be the optimum setup)
Posted : 16/10/2009 11:13 am
Same i2i James. I was hoping someone had done/attempted it to save me looking into axle paths. Good plan about letting air out of the current shock, that will give a rough idea on the space available.
Giant use the longer stroke shock on their reign-x which has essentially the same rear end, but I've already put on longer forks so Giant's geometry engineers are already disappointed in me anyway ๐Ÿ™‚
Posted : 16/10/2009 11:14 am
yes .. it works fine on all Reigns, all years
Posted : 16/10/2009 11:32 am
Cheers peakprowler, I may well give it a go then
Posted : 16/10/2009 11:48 am
dont try to run a piggy back shock tho, they only fit '08 onwards
Posted : 16/10/2009 8:41 pm
