Handle bar diameter...
[Closed] Handle bar diameters
8 Users
I enquired at my local LBS about a shorter stem for my Rockhopper, going from a 100mm to 70mm, however they said that the norm is to have 31mm bars whereas mine is 25mm.
Is this correct and if so new bars required, a chance to try 700mm bars then!
Posted : 02/11/2009 11:50 am
LBS trying to pull a fast one. Bars/stem can be either standard clamp size (25.4mm) or oversized (OS 31.8), you can still get plenty of bars and stems in either - there's no 'norm'. My guess would be that LBS only had OS stems in stock and tried to BS you.
Posted : 02/11/2009 11:55 am
It's the 'norm' for the latest stuff I reckon but definitley not the norm overall.
they probably just didn't have the right length stem in non-OS...
Posted : 02/11/2009 11:58 am
Thanks for the above comments, has anyone fitted the Cyclelife/Outland D31-eight bar stem grip setup. Seems good value all in at £40ish.
I think STW used these with the multi use article acouple of monthe ago
Posted : 02/11/2009 12:03 pm
Your bars are just as Normal as OS 31.8mm,
sounds like the LBS Gibbon is just too lazy to find a 25.4mm Clamped stem...
There's about a million available...
Posted : 02/11/2009 12:11 pm
 juan
or you could buy a 31.8 and get it shimmed...
Posted : 02/11/2009 1:14 pm
I have a 28.4mm bar, am I normal too?
Posted : 02/11/2009 1:17 pm
No, you're weird 😉
Posted : 02/11/2009 1:19 pm
I've got a Tioga O-bone stem in 80mm 25.4 clamp I could send you for about £8 posted if you're interested. 1 week's use. Email in profile if you want it.
Posted : 02/11/2009 1:30 pm
smartay,
The Outland bar and stem combo is very good. I found the bars had too much rearward sweep for my liking but they maynot be for you. Stem was robust although the bolts were porly finished and started to rust slightly.
To be fair I find it odd that an lbs didn't have a 70mm 'normal' stem. That said there are plenty around on e-bay, in Halfords, Evans etc... No need to spend £40 on a new bar/stem combo.
Posted : 02/11/2009 1:42 pm
 juan
Nope but it's not very common though.
Juan
Posted : 02/11/2009 1:51 pm
