Hand pain on the ro...
[Closed] Hand pain on the road bike 🙁
Like cramp at the base (pad) of my thumb 🙁
I know i have only been out twice but on descents it REALLY hurts!! How do i set up bar level - should they be flat, raised, down??
Also shit scared of riding in the drops, any tips?
Posted : 05/01/2012 11:08 am
It might be that the front of your bike's too low for you and you've got too much weight on your hands (this might also make riding in the drops scary!)
This is how my bars are set up (eg flat on the hoods) but you'll see lots with the brake levers pointing up more
Posted : 05/01/2012 11:09 am
are you using mtb gloves - they sometimes have paddign int he wrong places for riding on the hoods of road bars for long distances?
also have you got too much weight on your arms due to bike fit?
I rarely rode in the drops - really only for a few seconds if I wanted to sprint or on faster downhills if I was coasting.
Posted : 05/01/2012 11:10 am
 wors
Mine did that for a while, it eventually goes, maybe lift the handle bar height a touch to take a bit of weight off your hands. I very rarely ride in the drops, nearly always on the hoods.
I had this - try tilting your saddle up a little - as it might be pushing more of your weight on the bars.
moving your saddle back helps balance your weight more too.
but you'll also have to get used to it - it will take a few weeks.
your confidence will come - I did a post like this about 1 year ago 😉
Posted : 05/01/2012 11:13 am
Riser bars 😉 like ones on a mountain bike.
Posted : 05/01/2012 11:22 am
use gel inserts under your bar tape - make a noticeable difference to comfort/road buzz
Posted : 05/01/2012 11:26 am
Position is far more critical on a road bike because you don't move about as much as you do off road. Clubber's looks like a good set up and is v similar to mine, so I'd echo the flat hoods from raised bars cause first. Even shorter stem perhaps, but defo keep your saddle level. I use a spirit level! All of this is conjecture as you may be an extremely odd shape in the length of limb department. The best decision is a proper bike fit or failing that an on line free one with somebody like this, http://www.competitivecyclist.com/za/CCY?PAGE=FIT_CALCULATOR_INTRO (sorry I don't know how to do the linky or photo things)
 anc
Tilting your saddle up generally isn’t such a good idea on a road bike most would be flat or pointing down a little depending on your flexibility, if you tilt if back you'll get pressure on your sensitive bits when your down on the drops. If your hands hurt its about body balance and probably just the fact your not used to riding in that position. Also most handlebars are designed to tilt slightly down on the tops unlike the flat position clubber has (but if it works for him thats great 😉 ), a good starting point is having the bottom of the drops parallel with the road. This creates a natural comfortable recess for the hand on the top of the bar and the huds.
This shows what I mean with the bars.
Posted : 05/01/2012 11:38 am
you are doing it wrong.
all 3 bar positions should be easy to use without discomfort. poor flexibility can be the problem but usually it's just poor bike fit.
as for the op's hand pain it's possibly a positional thing on the hoods and you need to move or rotate the hood until your hand is supported all the way round the palm from base of forefinger to base of thumb/fleshy part of palm. but if the bike is too short or long the wrist angle may be wrong. something a novice is unlikely to notice but would be picked up instantly with a good bike fit. without seeing pics of you sat on the bike it's difficult to suggest a definite cause
Posted : 05/01/2012 12:00 pm
Rubbish. Sorry.
Posted : 05/01/2012 12:01 pm
[i]poor flexibility can be the problem[/i]
this - I even got a letter published in stw about my lack of 'give'.
I get dreadful neck ache if I ride on the drops for more than a few minutes. I tried raising bars etc but I ride a slicked up mtb on the road now.
Posted : 05/01/2012 12:05 pm
Rubbish. Sorry.
so you have some physiological disability that prevents you from using the drops? only despite popular myth the drops are not just for sprinting, you go faster in the drops due to lower body position (if you have the flexibility to use them) if you are doing some work on the front then they are more or less essential if there's a bit of a headwind or you have to work too hard if you remain upright on the hoods/tops.
Posted : 05/01/2012 12:10 pm
anc - bars used to be like that but most now run flat into the hoods. Depends on the type of bend in your bars so its hard for us to comment. Also I'd start with the bottom of the bars angle fractionally up as a starting point as both and and clabber's photos show, then move hoods. Sort overall position and then tweak is the way forward.
Posted : 05/01/2012 12:11 pm
Also most handlebars are designed to tilt slightly down on the tops unlike the flat position clubber has (but if it works for him thats great )
Think it depends on the style of the drops as the curve down can be quite different on drops from different brands and styles, mine are more like clubbers - flatter on top then curve down in several straightish sections
Posted : 05/01/2012 12:23 pm
 anc
Nar far more pro/elite guys run there bars with a slight angle down, have a shifty through the pro bikes on bikeradar. That said its about what works for you. I used to run mind flat but as my flexiblity improved i discovered the angled down bar worked better for me.
Heres Andy Schleck's bike with a slightly less of a angle to wiggos above but still angled down.
Posted : 05/01/2012 12:27 pm
Does the fore/aft position of the seat have a big effect on hand problems? I do get pretty numb hands on my road bike but I've got a Thomson inline post and looking at both the bikes up there, they have quite a lot of layback.
Should I be looking at a layback to help get weight off my hands?
Posted : 05/01/2012 12:31 pm
i was having very similar issues:
First off, i changed my bars from some ritchey ergo bars to the shallow drop 3T ergo nova, then i dipped my bars down a touch and then raised the hoods up a bit (much like Schleck's bike above)
I later had a bike fit where they moved the saddle forwards 10mm and then extended by stem length by 30mm.
Posted : 05/01/2012 12:33 pm
no. change seat position for knee over pedal/saddle height etc. change the front of the bike (stem length/bar height etc) to change weight distribution.
wiggins bars look pretty flat at the top onto the hoods:
think it down to personal setup and also hood shape varies a lot beteen brand and model
think the main things is to set up so you are comfy
Posted : 05/01/2012 12:34 pm
this
shouldn't this be forward? your weight will sit further back and you'll be more upright if you bring the saddle forward. counterbalance
Posted : 05/01/2012 12:35 pm
I don't know if I'm doing it wrong but I rarely use the drops too, and need to get me a higher rise stem as leaning down to the drops gives me massive neck and head aches and pulls my lower back. I do have "the tightest hamstrings I've ever seen, tighter than someone twice your age" - (sports physio). I'm working on it but that pulls my back out too.
Posted : 05/01/2012 12:36 pm
tried a foam roller?
Posted : 05/01/2012 12:42 pm
I read something about when standing if you bend over you arse will stick out to counterbalance you - it said the same is true in bike fits???
dont read anymore get a bike fit, or change one thing at a time and feel for improvements!
I would say, that as you've only been out on your road bike a couple of times, and as you are scared of using the drops......
You are probably holding the bars too tight. Assuming that your set up is not a million miles out (a photo of you on your bike would help here), then it's just a case of relaxing and getting used to it.
There is no right or wrong way for your bars or saddle. Personally, I have my saddle tilted very slightly back and cannot understand how anyone can ride with the nose pointed down, but lots do and that great. Same with bars. Some people like the hoods high, some like the drops tilted forwards. I like shallow drops set slightly back, because I have stiff wrists.
But/and.... one of the great things about roadie bars is that you have so many hand positions, so you can to change regularly.
SB
Posted : 05/01/2012 12:58 pm
 anc
rootes1
Wiggo on stage 4 of this years Vuelta with a slight angle down 😉
as you say though whatever works for you.
Posted : 05/01/2012 1:02 pm
MrSmith - Member
I suspect reading back that we might be talking at crossed purposes, but plenty of people rarely use the drops - not because they can't but because they prefer not to. My comment was to the idea that some roadies have that you MUST use the drops or you're doing it wrong - maybe that's not quite what you were saying.
Posted : 05/01/2012 1:05 pm
Can I point to the obvious, while it's all well and good highlighting the pro's bar position, they are really rather good at riding road bikes while the gentleman posting the original question is really rather, at riding a road bike, to coin his own oft' used phrase..."shite".
Not much use in advising flat or negative degree bar position at this point based on elite or professional riders preferences.
Just sayin'....
Posted : 05/01/2012 1:12 pm
I mainly use drops for descending and heavy braking oh and if its windy
you can get shallow drop bars too
Posted : 05/01/2012 1:14 pm
 anc
Hehehe .. quality
Yeah but their pro's and they do it every day so a comfortable hand position is quite important...
Just sayin'.... :mrgreen: 😆
Posted : 05/01/2012 1:15 pm
see if you can borrow some different size stems - it will all take time to figure out yourself though - get a fit and tweak from there. thats your best bet
Posted : 05/01/2012 1:20 pm
lol @monksie
You are putting too much weight on your hands and giving your ulnar nerve a hard time. Get your bars up! Level with the saddle or a drop of about 1" below saddle is a good start. Ignore the pros. Move saddle forward slightly so that when you are pressing on the pedals, there is little weight on your arms. I think bar height is more important than rotation. Get that right first.
For riding on the drops: DO NOT WEAR A HELMET VISOR! Don't expect to be looking too far ahead for long periods. The kink in your neck can trap the nerves (been there, done that 😥 ). I tend to look at the front wheel and kerb, then take the odd glances up.
To improve flexibility, I tend to set myself a goal of a certain section or road that I will ride on the drops. Then I lengthen that distance. Of course into the wind yesterday, it was stand up and honk or get as low as possible!
Most people ride on the hoods for most of the time. Don't expect to be any different 😉
Posted : 05/01/2012 1:24 pm
the thing about pro's set-ups is they are nearly always using a 130-140 stem, very few spacers and the bikes always look a bit small to the untrained eye. this long stem/low position puts more weight over the front wheel and makes the bike stable despite it being a bit shorter, descending/cornering is a lot easier when the balance is right, the typical nodder position of high/upright with the weight bias towards the saddle means the bike handles poorly.
get some flexability/core strength and a longer stem 😆
Posted : 05/01/2012 1:28 pm
10:00am Saturday from Hope mate? Edale Rd hill reps?
"I tend to look at the front wheel and kerb, then take the odd glances up."
That would scare the life out of me! Both doing it or riding with you. Exciting certainly 🙂
Posted : 05/01/2012 1:29 pm
My commuter set up. Can spend about 30% of the ride on the drops. I seem to have an upwards bar! But very comfortable. I'm 5'11". Wiggins and Schleck are huge, so don't copy them!
EDIT
And of course trail has nothing to do with handling? Not a huge fan of tiller steering on road or MTB.
Posted : 05/01/2012 1:31 pm
Well obviously peripheral vision adds to perception. The wheel in front isn't going to be 30m further up the road (hopefully). 🙄
Posted : 05/01/2012 1:36 pm
rootes1
hmmn perhaps he fancied a change 😉
as for use of the drops, I only use mine downhill and when it is windy with only occasional use at other time - tops or the hoods are normal - I have nice cork tape with gel under - find the gel really does make things more comfy. think partly due to the vibration absorption but also the increase in grip diameter for big hands
Posted : 05/01/2012 5:18 pm
would carbon forks help also?
Posted : 05/01/2012 7:03 pm
I like my drops facing slightly down, that way I feel like I'm falling into the drops and not clinging on. I'm very inflexible as well, but like this I can ride and race all day in the drops.
Posted : 05/01/2012 7:42 pm
 jeb
1. get chiba gloves or specialized gloves, with lots og gel
2. shorter stem, i ride a 60 mm, absolutely love it, keeps the cockpit real short! -bikecomponents.de has some nice one, called procraft.
3. look for a handlebar with short reach, and curvy drops, like fsa:
http://www.chainreactioncycles.com/Models.aspx?ModelID=50187
When getting a new frame, look for a tall headtube, like 17o-190 mm
4. wrap gel, or slice an old tube, and wrap it under your handlebartape.
Sorted 😆
Posted : 05/01/2012 8:10 pm
Probs been mentioned already (not read whole thread) but, what's the saddle height in relation to the bars like? Too high might put unwelcome pressure on your hands & wrists. If this is the case, could it be your frame is a little too small? .
Just a thought.
Posted : 05/01/2012 8:34 pm
jeb for me less is more. As little padding as possible. No gloves in summer under two hours. I find padding squirms and moves and causes hot spots. I only run bar tape to the hoods.
Posted : 05/01/2012 8:35 pm
 jeb
oldgit, jesus, you must have heavy callusis on tha hands!!!!??? no gloves in summer, oh dear, dif horses for courses... 😯
Posted : 05/01/2012 10:05 pm
Well we're all different, I get sore hands with too much padding. My road mitts have no padding, just an extra layer of leather. I use BG mitts for cross but I used a scalpel to remove the gel bit. And I don't think any winter gloves have any padding at all do they?
Another guy in our club has very serious hand pain, sometimes he has to go home after a mile.
So basically anything that moves between the bar and my hands is uncomfortable.
Posted : 05/01/2012 10:19 pm
Just got my first drop-bar road bike in the last few weeks after years of riding flat-barred MTBs with suspension and hybrids for commuting or touring.
No issues with any aches and pains anywhere, which surprised me - apart from my hands. Glad it's not just me.
Think a certain amount of it might be tension from just being uncomfortable with an unfamiliar posture on a bike that is quite skittish compared to anything else I've ridden - especially on descents, WRT hand positions that are not an unfurled index finger away from the brakes.
Just bought some ergo-shaped bars on the classifieds - hoping the flat tops of the bars will suit my default hand position - resting the "balls"(?) of my palms on the tops of the bars, a bit better.
Also, dunno how much any of us MTB-ers who ride on the road occasionally have to learn from pictures of top pros - surely their set-ups are optimised for performance, for being a few hundredths of a second quicker than the next guy, rather than comfort. A bit of hand pain is probably the least of their worries. 😕
Posted : 05/01/2012 10:23 pm
first thing that costs nowt - flip the stem, play about with the bar angle, rearrange the spacers so the bars come up. Then you can slowly drop them a bit at a time until you find the right bar height and position
second thing, do some regular stretching, before and after the ride - again costs nowt
[edit: keep remembering things] don't grip the bars too tightly, bend the elbows. hoods aren't for riding long stretches on, use all the different hand positions as that's why they are shaped like that, for variety
something that costs very little - double wrap the bars, simply put a second layer of bartape on top of the first, cost about a tenner
also, fresh pair of gloves as they compress over time and lose the padding (prendas knock out really good ones for much less than the high street prices)
Posted : 06/01/2012 12:34 am
This is pretty interesting - I've only just got my first road bike and the bars were set up straight; but after the first ride set them with a slight drop as it felt weird straight! I thought I was being weird but glad to see I'm not!!! I've just bought latest cycling plus (hangs head in shameful guilt) and it has some pretty useful tips on setting up your bike - I need to gety saddle sorted as still too much pressure going through arms shoulders neck.
Your hand pain does sound like a trapped nerve issue - I used to get it wearing a pair of spesh BG gloves but changed to endura and all good - strange
Posted : 06/01/2012 1:52 am
not saying your position doesn't need tweaking but the more you ride the more your core/upper body gets used to supporting your weight.
Posted : 06/01/2012 12:31 pm
regarding the brake levers - should they be at 90 degrees to the ground?
Posted : 06/01/2012 9:28 pm
 juan
I would suggest you learn to position yourself on the biek a bit better. Road biking position is not like mtbing. You need to sit on the saddle the same way you would sit on an office chair with your back straight and your core muscle to maintain it that way, and then you will have to pivot around your hips to reach the handlebar. Pressure pain in the hands is due to people not using their core muscle and using their hand to sustains their weight
HTH
Posted : 06/01/2012 9:56 pm
get a bike with dt shifters,or bar end shifters.constantly moving your hands is something that integrated brake/shift levers discourage.
or just remember to move your hands around.
Posted : 06/01/2012 10:24 pm
I'm with oldgit on this. I don't NEED gloves because the weight on my hands is not so great. Saddle position is key, and pedaling should take the weight off. Once saddle is correct, then think about the bars. Oh and core body strength helps.
Posted : 07/01/2012 1:11 am
