Halo Tundra rims Tu...
[Closed] Halo Tundra rims Tubeless or nay?
Hi have a halo 80 mm tundra rim can I use tubeless?
If so is it straight forward?
Posted : 14/11/2017 8:41 pm
Yes, but it's not super easy- if you look in teh massive Calibre Dune thread, it's the exact same rim just with different shaped cutaways. I got hte best results with a mix of electric tape and jiffy foam, and the easiest results with foam and a cut tube. But it was always a pain in the cock- totally worth it mind.
Posted : 14/11/2017 10:02 pm
i did mine ghetto tubeless because it failed a few times trying the tape way, ghetto for the win ๐Ÿ™‚
Posted : 14/11/2017 10:56 pm
What's the foam for?
Posted : 14/11/2017 11:01 pm
Builds up the rim bed a bit and takes away the gap- makes it way easier to inflate. It doesn't do anything once the tyre's up
Posted : 14/11/2017 11:45 pm
Thanks so what size inner tube would I use?
Posted : 15/11/2017 7:04 am
I used a schwalbe AV10- it's just barely wide enough so you have to cut it carefully, but it's cheaper and lighter than the AV10D that most people recommend.
Posted : 15/11/2017 5:19 pm
Posted : 15/11/2017 7:24 pm
