Halo Hex key skewer...
[Closed] Halo Hex key skewers, what size?
Alright, as above really...... standard or XL, running normal mavic 318's. Standard • Size: Front (100mm); 6.0mm thick
Rear (135mm); 6.5mm thick
or Extra long, maximum dropout capacity;
• Front (100mm); 11.0mm thick.
• Rear (135mm); 10.0mm thick.
So, which ones?
cheers!
Hubs are: Front: Kona OB-1, Rear: Shimano Alivio
Posted : 12/11/2010 4:08 pm
I went with a std set for my swift.
Posted : 12/11/2010 4:47 pm
Depends on your frame/forks surely?
Posted : 12/11/2010 4:50 pm
Salsa Cromoto on the front, 8 speed cassette on the back, But it's the "thickness" thats confusing me though (length is the same on both sets)
Posted : 12/11/2010 5:04 pm
Length isn't the same.
The 100/135 is the width of the hub.
So guessing;
Standard front 112mm, rear 149mm
XL front 122mm, rear 155mm
Posted : 12/11/2010 5:12 pm
The thickness quoted refers to the maximum thickness of the dropouts the skewers are designed for. With a Salsa Cromoto on the front I'd guess you'd need the regular. I bought a set of XLs for my Tazer hardtail as the dropouts combined with the tensioners needed the extra length - a standard skewer did the job but was only holding by 5mm or so of thread. Its replacement (watch this space 😉 ) although chunky, is fine with the standard length skewer (in fact the XL protruded too much, although it clamped fine).
Posted : 12/11/2010 5:44 pm
Standard, and don't over tighten them. The end will ping off. 😳
Posted : 12/11/2010 6:07 pm
