Halo Clickster SS F...
[Closed] Halo Clickster SS Freewheel
[#11985395]
Afternoon all, I've just picked up a used Charge Cooker single speed to replace one I regret selling a while ago. I need to fit a smaller freewheel, and have seen that Halo Clicksters come highly recommended but are only available in 3/32" pitch. My chainring and chain are 1/8" - from what I recall this should still work, however.
Have I got that wrong? Will the chain 'rattle' a bit at the rear or is the width difference negligible?
Thanks very much for any advice.
Posted : 03/08/2021 1:04 pm
Will work fine - if your chainline isn't dead straight it will be a bit noisier, but nothing that will drive you too mental I expect.
Posted : 03/08/2021 1:06 pm
I’d spend the extra and get white industry’s freewheel. I went through lots of shimano/halo etc but never destroyed a white Indy one !!
Posted : 03/08/2021 1:16 pm
Just a small nitpicky point, sorry etc... A chain's pitch is the distance between the roller centres not the distance between the internal side plates. Sorry again etc...
Posted : 03/08/2021 1:22 pm
 Del
Not convinced they're worth a premium. Fwiw I've worn out three of them. If you have some mechanism to take advantage of a good exchange rate they're worth it but otherwise just get something you can replace relatively cheaply and easily. I run regular freewheels now with surly cogs. They're just easier to deal with.
Posted : 03/08/2021 1:37 pm
The WI looks nicer than the Halo but both work fine and both are many times better than the sloppy and knocking noise £10-20 freewheels.
Posted : 03/08/2021 2:00 pm
Thanks chaps, I appreciate the replies.
However, it's not as straightforward as I hoped. I took the back wheel off and it appears that there is a freehub with a locking holding a single cog on, not the freewheel I'd expected. Has anyone seen this set up before?
Posted : 03/08/2021 2:32 pm
That's a single speed hub that allows for a bit of chain line adjustment with the spacers. Just order a new single speed cog and slot it onto the splines.
Posted : 03/08/2021 2:39 pm
The surly cogs are very nice.
Posted : 03/08/2021 4:20 pm
Thanks very much @qwerty . Isn't that a bit of a nightmare when it comes to servicing? Normally if a freewheel dies it can be replaced - Does this need a new hub?
Posted : 03/08/2021 4:35 pm
Bearings look easily replaceable.
Posted : 03/08/2021 5:41 pm
These from Planet X are OK too:
https://www.planetx.co.uk/i/q/SKOOSSGA/on-one-groove-armada-single-speed-sprocket
Posted : 03/08/2021 5:45 pm
Isn’t that a bit of a nightmare when it comes to servicing? Normally if a freewheel dies it can be replaced – Does this need a new hub?
If the freehub dies then you would be in trouble but bearings can be easily changed and as you are currently after just a smaller cog then you can just buy something like a Halo fat foot in 17t, 16t or whatever you require which is 1/8 and has a wide base
Posted : 03/08/2021 6:02 pm
Thanks very much chaps, it's appreciated - 16t Halo cog on order!
Over the bearing there's a plastic conical seal, then a washer, then a knurled 15mm nut. How tight should that be? I'm guessing it has no effect on preload?
Posted : 04/08/2021 9:56 am
