Had a thought - rea...
[Closed] Had a thought - rear shock swap
So I have a Turner 5 Spot DW with an RP23
Wife has a Superlight with a Float R (although I ride it as much as she does)
The shocks are the same size and according to the sticker on them both have the same compression tune.
Given that I never use the pro pedal on the Turner (it just doesn't need it) and the Superlight can be a bit bobby should I just swap over the shocks?
Would the Float R just feel like an RP23 with the pro pedal switched off?
Posted : 31/05/2013 9:21 am
That makes sense. Myself and the missus run a Marin Rock Springs back to back with a Wolf Ridge (the only difference aside from frame size is that the WR has an RP23 and the RS has a Float). TBH I prefer the feel of the Float, they do have pro-pedal but it's a compromise tune so that it doesn't choke the suspension.
You could do a lot worse than to swap them and see how it goes.
Posted : 31/05/2013 9:31 am
For the 5 mins it will take you give it a go, you can always swap back
Posted : 31/05/2013 9:32 am
Thanks guys, I'll give it a go
Posted : 31/05/2013 9:57 am
