Gx eagle with xt cr...
[Closed] Gx eagle with xt crankset? On a boost frame
Will this work? Can I use a standard boost crankset with 11speed shimano chainring? What other chainring could I use if this doesn't work? I had heard they where compatible...
Posted : 22/11/2017 8:06 am
Ive used a 12 speed chain on 11 speed drive by accident and didn't even notice until I went to change it...
Posted : 22/11/2017 8:25 am
So long as the chain line is right for 1x,ran my old 10sp sram cranks with the new gx with no issues.
Posted : 22/11/2017 9:08 am
I have GX eagle with a M785 double fitted with an absolute black oval ring. Fine for me. It's not boost but as long as the chainline is fine it should be ok.
Posted : 22/11/2017 10:13 am
It will ‘work’ but may not have quite such good chain retention as the full set with intended chain and chainring. It’s quite a tooth on the Eagle rings.
That said, you may not notice a problem...
Posted : 22/11/2017 1:06 pm
