Guide to bleeding S...
[Closed] Guide to bleeding Sram Guide R brakes
5 Users
I'm attempting my first ever bleed and I'm looking to recommendations of the most accurate/informative instructions out there. Videos, articles or documents - I don't mind.
Also, any pro tips from your own experience of your first brake bleed?
Thanks!
Posted : 05/03/2018 10:00 am
If they have calipers that require the Bleeding Edge tool see this video
Posted : 05/03/2018 10:12 am
If you need a kit try here :
http://www.epicbleedsolutions.com/products/bleed-kits/avid/
Comes with instructions - follow to the T and you'll be done in 10mins. Easy.
Posted : 05/03/2018 11:21 am
Thank both - ordered the kit from Epic Bleed Solutions.
Fingers crossed, I won't mess it up!
Posted : 05/03/2018 12:40 pm
That kit will work - possibly.  >2017- Guides use the Bleeding Edge tool, which Epic don't currently do.  If they are <-2017 then the normal kit should work.
Posted : 05/03/2018 12:43 pm
As teethgrinder has said, there are 2 types of caliper. Best to check which one you have first
See the difference in the bleed ports here (just scroll down a bit)
-   http://www.epicbleedsolutions.com/resources/faq/what-is-sram-bleeding-edge-tool/
with the correct tool its a doddle
Posted : 05/03/2018 12:51 pm
Thanks - I have the traditional bleed port on mine. My brake's from 2015 or 2016.
Posted : 05/03/2018 1:30 pm
