So it turns out you actually can't just fit adapters to centerlock wheels to fit 6-bolt rotors. Specifically Fulcrum.
Why? Why did Campagnolo put the tread on the outside so that the center hole of the disk doesn't clear it? No one else does, every other hub has it internally. But not f****** Fulcrum.
Grrrrrr.
Nothing clears it, Shimano, Hope, Avid, SRAM, Ashima, Alligator, none fit.
Pissed off. Just bought a (comedically large) Hope 220mm floating rotor and set of DT adapters that are useless until I get some new wheels built.
Posted : 05/06/2020 2:52 pm
