Grinding noise from...
[Closed] Grinding noise from road bike drive chain under power
I can't work out what's causing the grinding noise in my drivechain! No noise whilst on the flat but nasty grinding noise as the road steepens and I start putting some effort in. Rear hub seems to spin freely as does the freehub and the cranks in the external BB. Any ideas?
Posted : 15/02/2009 8:04 pm
Chain rubbing on the front mech, when you put the power down flex in the frame/chainset may be causing it to rub.
Posted : 15/02/2009 8:06 pm
Your muscles crying out.
Posted : 15/02/2009 8:20 pm
Loose rear hub allowing tyre to touch the frame under power?
Posted : 15/02/2009 8:36 pm
Bottom Bracket?
Posted : 15/02/2009 8:38 pm
Frame flex?
Posted : 15/02/2009 8:49 pm
BB cups a bit loose? Chainring bolts? Rear qr tight? Pedals tight?
Is it worse in any particular gear combos?
Posted : 15/02/2009 8:51 pm
As it happened when I was climbing I was on one of the lower gears so migt be the front mech; surprised as no problem on the previous ride. The chain was pretty dirty so cleaned that up and everything else incase something was sticking somehow.
Posted : 15/02/2009 11:29 pm
