Greasey spots on tu...
[Closed] Greasey spots on tubeless tyres
I have a Conti Rubber Queen on my rear wheel filled with Stans. It always has 10p piece sized greasey looking patches on it where I assume I have punctured and the Stans has done its business.
I'm not losing any notable pressure but these patches have been on the tyre since June and keep returning after rides/cleans etc... I never got this on the Schwalbes which were on previously or on my front tyre which is still a NN.
Is this normal? Why does it only happen on this tyre?
Posted : 22/09/2014 4:24 pm
Had em on Conti Rubber Queen UST,and Baron's, and on Schwalbe Hans Damph's. Swapped to Maxxis after tearing started on the HD's. Nothing comes through em. Have Ardent,Ikon and Minion's. Don't worry just keep riding ๐Ÿ˜†
Posted : 22/09/2014 6:26 pm
 JoeG
It happens sometimes on some of my tubeless tires w/Stans. Doesn't cause any problems...
Posted : 22/09/2014 6:28 pm
It's the glycol weeping out of the solution slowly through the puncture holes. You lose water from the solution too, but it comes out so slow that it evaporates, where as the glycol doesn't ( which is the point of it, as well as lowering the freezing point of the fluid) glycol is 'a bit greasy'.
Posted : 22/09/2014 9:19 pm
I get this too, thanks for the answer as to what it is.
Posted : 22/09/2014 9:27 pm
I've had this with Conti X-Kings . Keep an eye on your sealant levels , it used to cost me a fortune replacing the Stan's that weeped out .
Posted : 22/09/2014 9:29 pm
Don't use Continentals anymore !
Posted : 22/09/2014 9:30 pm
I find it's actually pretty useful. It gives a good indicator of how much hammer a tyre has had. I'm using Hans dampfs at the moment. New, they go up fine and don't weep. After a bit of officer hammer time, they then develop plenty of spots!
Posted : 22/09/2014 11:12 pm
Thinner/older tyres get more wet patches, but not a problem just an indicator of how well the spunk is working ๐Ÿ™‚
My old RoRo appeared to be mostly damp patches, the new dual defence RaRa is as dry as a bone.
Posted : 22/09/2014 11:58 pm
you di..r..ty old man ๐Ÿ˜‰
if it's causing you grief then patch it from inside like a normal puncture repair, otherwise the sealant is doing it's job and no worries
Posted : 23/09/2014 9:54 am
Thanks for the responses, glad I'm not facing imminent death. I appear to have 31 punctures in my rear tyre but am losing no pressure. Also I never had to fix the 31 punctures in an inner tube.
Posted : 24/09/2014 7:13 am
Kerching!
Posted : 24/09/2014 11:23 am
* chuckles * officer hammer time
Posted : 24/09/2014 11:41 am
In one of those "Hey look at all those holes" moments I counted the patches on both bikes. I make that over a hundred times I haven't had to stop and mend punctures. One of then is a 8 or 9mm cut that may well not have done a new tube any favours, so that's a long faff and tyre boot moment saved as well.
Ain't tubeless brilliant!
Posted : 24/09/2014 11:53 am
