Got rid of Tacx Flo...
[Closed] Got rid of Tacx Flow 2240... Bkool or Elite? Will I need BLE?
As I was so unimpressed with the quality of the Tacx Flow 2240, I returned it for a refund. That leaves me with the tricky decision what to replace it with - ideally asap, because I miss Zwift already 😀
The Bkool Smart Go is the nearest in price, but I understand it doesn't support BLE - will I notice this when using Zwift :oops:?
Elite do the Qubo Digital Smart+, CRC have it at £300, but not in stock till mid Feb (how reliable is their stock prediction...?!).
Elite also offer the Rampa at £400, it's in stock at Wiggle...
Has anyone got experience of these? In particular, is the build quality good? I was really disappointed how badly the cover of the "motor" of the Tacx Flow was attached.
Posted : 26/01/2017 3:38 pm
BLE is only essential if you're Zwifting on an iPad, otherwise you can just use an ANT+ dongle.
Posted : 26/01/2017 3:41 pm
Only reason I'd notice it missing was using bluetooth to update the software on the machine.
Posted : 26/01/2017 3:55 pm
I have that elite qubo, the motor cover on it is also really poor, but unless you plan on throwing the thing around it makes no difference.
Posted : 26/01/2017 3:59 pm
Thanks for the bluetooth clarification!
trailwagger - Member
The Tacx cover "unclipped" itself the third time I used the turbo and the fan then touched the cover all the time, which made a really annoying racket. I guess you've been using yours for longer and although poorly made, the cover hasn't moved?
Posted : 26/01/2017 4:02 pm
I've had an Elite Qubo Digital Smart B+ Fe-C Trainer for a little while now. Appears to work well - have been using it for rehab from a knee injury. Have also tried a Rampa which is a bit heavier / sturdier, can generate more power and the larger flywheel keeps momentum for longer if you stop pedalling but this wasn't enough for me to want to spend the extra money.
No idea how reliable their stock prediction is! Have you tried a local shop? I work in a bike shop and we have both of the elite models you mention in stock.
Posted : 26/01/2017 4:10 pm
😳 Guilty, I haven't - is your bike shop anywhere near Stirling 😉 ?
Posted : 26/01/2017 4:35 pm
Sadly not!
Posted : 26/01/2017 4:38 pm
iOS Zwift now supports the Wahoo Ant+ adaptor.
Read DC Rainmaker's reviews of any trainer you're thinking of.
Posted : 26/01/2017 7:59 pm
At that price id be going for a factory refurbished Kickr Snap, £399 direct from Wahoo.
Posted : 26/01/2017 8:20 pm
Out of stock when I looked on Monday. So I went new on finance via Wiggle
Posted : 26/01/2017 8:31 pm
Kickr Snap £450 from CRC with BC discount.
Posted : 26/01/2017 8:33 pm
Booo... I just saw they are out of stock as well. Will look at wiggle finance...
Posted : 26/01/2017 8:35 pm
Thanks, I did - unfortunately for me he rates all of them much of a muchness 😀
Posted : 26/01/2017 8:45 pm
