Goodridge gear cabl...
[Closed] Goodridge gear cable outer - is it the same diameter as brake outer?
[#718766]
ie 5mm?
Posted : 19/07/2009 4:39 pm
bump????
Posted : 20/07/2009 12:15 pm
 Olly
generally, brake cable outer is much thicker than gear cable.
the internals are toally different too.
Gears are made up of thin strands that spiral gently along the length, providing lower friction and better accuracy.
Brake cable is made up of a steeply spiralling "band" of steel, sharp as sin when you cut it, and not as smooth on the cable inner, but able to withstand much higher compression forces, which is good on brakes.
brakes are 7mm?
gears 5mm?
no idea about goodrich specifically.
Posted : 20/07/2009 12:18 pm
I beleive goodridge brake is 5mm (with the clear outer stripped off) or 6mm with it on and the gear cable should be 5mm (it is thicker than normal gear cable)
Posted : 20/07/2009 12:32 pm
just need an end cap (1 thats all) and don't want to pay £6 for goodridge gear end caps
Posted : 20/07/2009 12:40 pm
 Sam
Gear outer is designed so that it's length doesn't change as it's bent, nothing to do with friction or 'accuracy'. The outside diamter is usually 4mm.
Brake outer is a wound helical cable, also known as a Bowden cable. True that it resists compression better than gear outer. However both gear and brake outer will have a plastic liner in these times so neither design has anything to do with friction.
Posted : 20/07/2009 1:08 pm
if you just need a furrel then I would say 5mm... I could be wrong, but the goodridge cable I just put on is def bigger than the old cables I had
Posted : 20/07/2009 1:22 pm
Spankmonkey - Member
As the monkey says.
Goodridge gear outer = 5mm
Goodridge brake = 6mm
Shimano gear outer = just over 4mm
Shimano plastic gear ferrules are just a smidge to small for Goodridge.
The other problem is if the brake outer ferrule fits it may be to big for the frame's gear cable guide (depends on your frame you may get lucky?)
Posted : 20/07/2009 1:55 pm
