Hi, Heading up there tomorrow.
Anyone recommend a decent off road/singletrack ride nearby?
You're kidding, right?
You're right underneath High Street (good for a Big Day Out, lots of views etc), over the road is Helvellyn, (massive climb, choice of awesome descents), and just up the road is the Ullswater singletrack techfest, which you can make into a nice little loop by going over Boredale/Martindale. All rideable from your door.
Failing that, drive south for ten minutes and you've got Garburn/Nan Bield/Green Quarter and Jenkin Crag to play with!
How long do you want to ride for?
Have you looked at a map?
You're at one of the main access points for High Street - head east up onto The Knott and then North on High Street. When you get to The Cockpit above Pooley Bridge, double back to Martindale then follow the bridleway that hugs the shore of Ullswater down to Rooking and back to Hartsop.
A shorter alternative would be to head North from Hartsop and over Boredale Hause down to Martindale, either than or over Bedafell Knott onto Martindale Common.
Be warned that the weather forecast for this weekend in the North West is atrocious. Plus whatever the weather, this area is red-sock central.
No, haven't checked the map, we've gopt tghe kids and stuff but hoping to get out Sat morn early, so just seeing what we can pack into 5-6 hours really.
Thanks for the tips, will watch out for the red-sockers too.
If you've got 5-6 hours, go for High Street (as described above, but come back via the Ullswater trail!) or ride a short way up the road and go up Helvellyn. Choose the latter if you want a techy ride.
If the weather's horrific, the stuff between Kentmere and Ambleside (a short drive south) is a little lower down and less exposed, so might be a better bet. A ride out of Ambleside and over Loughrigg and Iron Keld would be a similar height. If it's really horrific, Whinlatter's not too far to drive if you want a trail centre, or Grizedale's a bit further if you want to be in the trees but on (awesome) natural stuff.
go to the pub.If the weather's horrific
Up Boredale Hause to Howtown returning via the lakeshore single track, even if the weathers bad its a great route, enjoy..
Thanks to everyone, really looking forward to a look around the area.
Have a great weekend.
Up from Hartsop to Hayeswater and head vertically towards the Knot but turn left to Angle Tarn and Boredale Hause and up to go through and down the other side of Boredale and down the valley to Sandwick and then smash through the rocky Ullswater shore path.
One of my favourite rides, but as I do it at night the shore isn't full of walkers.
Enjoy
We had a great ride Sat morn, the weather was spot on.
Anyone who rides regularly up here is so lucky.
where did you get to in the end?
