Good framebuilders/...
[Closed] Good framebuilders/painters?
[#715352]
I'm going to turn my shop/pub/gym bike into a proper ss mtb (if a ss can be a proper mtb?!) however I'm going to need some proper drop-outs putting on instead of the tensioner bodge I'm currently using as well as a disc mount and hose guides. Then it'll obviously need respraying as well...
Has anyone got any experience of doing this and which framebuilders did you use?
I realise it'd be cheaper and easier to buy a new frame etc etc but tbh if I was bothered about making life easier I wouldn't want a rigid singlespeed!
Posted : 17/07/2009 2:09 pm
Is it steel or aluminum?
Posted : 17/07/2009 2:18 pm
Steel - so should be easy enough in theory... (well, I'd have thought so but I'm asking strangers on a forum so I'm clearly not that confident!)
Posted : 17/07/2009 2:27 pm
Argos apparently do a top notch service, but for a price, I think.
Posted : 17/07/2009 2:50 pm
The problem with converting a frame to SS is that proper SS frames have stiffer chainstays. Bikes designed for deraiileurs don't need such stiff chainstays and can thus enjoy the benefits of a supple ride.
Hopefully it probably won't be a major problem, but your chain can drop if the chainstay flexes too much when you're stomping up a steep hill. This can cause eyewatering damage at the toptube/groin interface.
Proper SS frames are cheap these days - plenty 2nd hand.
Posted : 17/07/2009 5:11 pm
OP it is not cheap (£150+ as an estimate) and you will almost certainly be better getting an inbred unless your existing bike is nice.
Sorry but that is utter rubbish.
Even better! You must have some thighs to compress a chainstay that much.
Posted : 17/07/2009 5:15 pm
I've used Argos in the past to update and respray a DeKerf Generation frame. I couldn't have had better service - they even called to check the job before removong / adding the bits. As said, it was not cheap, but it was well worth it.
Again, as said, you may be better off simply buying a second hand (or new, for that matter) singlespeed frame, as the cost will be similar. It's all much of a muchness.
Posted : 17/07/2009 5:19 pm
