Going for a ride wi...
[Closed] Going for a ride with Geoff Apps and....
It feels like that is like one of these:
whilst modern enduro mountain bikes are more like one of these:
Au contraire! The Lancia was how mid-90s bikes rode. Modern trail bikes are like this:
Posted : 06/11/2014 5:05 pm
epicyclo - Member
Cheezpleez - Member
If I had the wherewithal to put a frame together, I'd love to build one of these.
You get a close approximation of that geometry by modifying an old suspension bike frame.
Just replace the suspension unit with a solid rod of an appropriate length, and you can dial in your head angle.
The fork then becomes the next hurdle, but again by modifying an old suspension fork into a rigid and locking in the right position you can get close. You can reverse the crown to fiddle with the offset.
About eight years ago I noticed that a small Giant NRS frame had the same frame fundamental geometry as a Cleland. If the suspension is run 'topped out', this even includes the higher than normal bottom bracket height as running 'zero sag' was recommended with the NRS.
So I bought an NRS, fitted a longer seat-pin and a long tall stem and a variety of other bits that Geoff was using at the time. Since then I have also built two others.
http://www.flickr.com/photos/38236150@N06/6936555047/in/photostream/
The only problem with this is that you have to use 26" wheels and in winter time, fit 1.9" wide tyres, because the mud clearances on the NRS or other mountain bikes are nowhere as good as those on the best Clelands.
I know of quite a few riders who have built their own Cleland style bikes. Probably because, despite the design being around for over 30 years, they can't go out and buy anything remotely like them.
Posted : 06/11/2014 8:43 pm
...and back to the thread I started. Not been logged on for a few days, and it's good to see a discussion going on!
I'm hoping to braze up a Cleland style frame over the winter, just need to source an appropriate tube set, and work out if I'm going to bother making a jig, or just bodging it 😉 I also need to find a cheap donor bike with either Nexus or Alfine gears on it.
Posted : 06/11/2014 9:08 pm
I found this on eBay:
http://www.ebay.co.uk/itm/carrera-subway8-20-in-frame-alloy-8-speed-needs-work-nice-project-/231374733556?pt=UK_Bikes_GL&hash=item35df0240f4
Sometimes people who specify 'collection only' may be happy to pop the bike into an old unwanted bike box from their LBS, and for the buyer arrange a courier to collect from them.
Also, Giant and Ridgeback made similar Shimano/Nexus inter8/Roller-Brake bikes a few years back.
Posted : 06/11/2014 10:05 pm
I love the project. It's the sort of thing that Pashley should try to make (to keep it British), but in reality it's sort of a Jones already. Make it out of titanium, change to fancier forks and sell it for $$$.
Geoff Apps' reasons for choosing big wheels, very low tyre pressures and motorbike inner tubes seem to be the same reasons why people now like fat bikes. So I wonder if Geoff will rethink and rebuild the Landseer to take the massive tyres.
Posted : 07/11/2014 12:36 pm
Nice work mudrider!
Posted : 07/11/2014 12:51 pm
mark a. - Member
Indeed, the fat-bike riders seem to share a very similar riding ethos to that of Geoff Apps.
However,the last time I rode with Geoff in July, he said that he thought that fat-bike tyres where too bouncy and did not have the handling characteristics he was looking for. I would say that his current thinking is more 29er+ based but using narrow rims. So maybe 700c or 650b rims with 3" tyres.
Two years ago I looked into the feasibility of building a fat-bike framed Cleland on which the wheels/tyres could easily be swapped over depending on the riding conditions. I still like the idea, but have no plans at present to build one. Though this could change if I found an off the shelf fat-bike frame with the correct geometry.
Though I like the idea of extra flotation, one issue I have with fat-bike tyres is their high rolling resistance in sloppy mud and potential for building up heavy mud deposits when riding in sticky conditions.
Having larger diameter,narrower tyres is probably the best "one size fits all" solution for a Cleland style bike. Though one frame and a variety of inter-changable wheel sizes sounds ideal, though expensive. Especially for the Rohloff geared bike I am currently working on.
Posted : 07/11/2014 8:34 pm
Page 2 / 2
