The shock bushing on my 2019 stumpy has a bit of play i.e needs replacing...
Opinoins on brass/ti/cheese below please, and best places to get them ASAP!
(It's a 20*6 ushing, standard 'fox/canecreek' OD), thanks...
DrP
If you mean hardware, I'd go to Bounce - they do normal or offset bushings in stainless which are really durable.
If you mean DU bushings, I rummage around the tins and toolboxes in my garage and always seem to find one.
My go to for shock bushings has always been TF Tuned.
Fox DU bushings especially the lower ones don't last long. I've replaced all of mine with the HD jobs from TF/Bounce.
Third vote for Bounce. Replaced the original bushing on my Fox shock with their HD hardware. Now only need to press on a polymer bushing when it wears out. Better performing, easier and cheaper.
For any shock bushings i use BETD , outlast anything else i have used and not massively overpriced.
I’ve always used www.offsetshockbushings.com the do offset or regular. They’ve always been well made and had no problems with them before (I have used TFTuned before them and couldn’t tell the difference). The guy who makes them is really helpful as well.
They were also cheaper when I last bought a set
