I'm just buying said camera but I'm hoping some of you lovely people can advise me on the memory cards! There seems to be a lot of chat about most SDHC cards not working with the camera.
Go Pro say class 4 and above. A 32GB card from the Go Pro brand of choice is £130 (!) but play.com has 32GB class 10 card for about £40.
Anyone use a Go Pro hd? What cards work for sure?
Sandisk 16GB (class4) from Play or Amazon £14.99, buy two for less than the 32GB job
Sorted
I had a class 4 and it worked - but must say I did upgrade to a class 10 and it made a big difference in the smoothness of the recording (and if you buy HD you want to see the proper results!!)
The faster cards copy the files to the computer much quicker. Makes a deference when your transferi 32gb files
Thanks Dango. Have you used these in a Go Pro hd? Are they definitely compatible?
Right! Class 10 it is then. Unless I can find a class 11!
I use class 4 16gb cards in my go pro hd, have about 5 of them
spend your money on a spare battery as you'll most likely get through that faster than the cards
I'm using Transcend 16gb class 10s, they're cheap and they work, nuff said really.
