Girlfriend in agony...
[Closed] Girlfriend in agony after bike rides , any simple solutions....
The girlfriend is coming back from bikes rides in agony down below , it doesn't matter if she's on her mtb or road bike, she has tried various saddles and shorts and hasn't really found any better than others, she only does 2 hour rides but she suffers from about 1/2 hr..
Anything else we can try , just for info she is very skinny ...
Anthony
Posted : 12/10/2014 10:00 am
A proper saddle fitting? She tried lady specific saddles?
Posted : 12/10/2014 10:02 am
Experiment with different saddle heights / angles?
Posted : 12/10/2014 10:03 am
selle italia according to my wife, made all the difference
Posted : 12/10/2014 10:05 am
Front, rear or middle?
Posted : 12/10/2014 10:06 am
New girlfriend?
Or perhaps, and a more helpful suggestion, higher rise / shorter stem to raise the bars at bit so she's not leant too far forward on the delicate stuff?
Hope she can get it sorted, must make it pretty miserable....
Posted : 12/10/2014 10:11 am
Yeah various ladies saddles but not sure what makes, her current road one has a cut out in the middle...think from what she describes it's her front that hurts the outer parts if I can describe it like that. She says it's like someone has cut her ...
Posted : 12/10/2014 10:14 am
She has tried vaseline, are there any better creams etc ..
Posted : 12/10/2014 10:16 am
Mrs Rexated use to term the exact same problem 'Little Red Riding Hood'! Sorted with Terry cut-out saddle and bike fit adjusted to have her back more on her sit-bones.
Posted : 12/10/2014 10:17 am
So how does she get more on the sit bones , saddle tilted forward / backwards ?
Posted : 12/10/2014 10:21 am
 poly
Fitting is at least as important as the saddle itself. A really good bike shop should be able to spend time (for £) getting her set up right. If she's in central scotland then I know a few ladies who report positive outcomes from similar issues using Hooked-on Cycling.
I think its also worth mentioning Chamois Cream (there is a new "female specific brand") and that this needs to be applied liberally. Anecdotal reports would also suggest that degree and method of trimming may have an impact.
Posted : 12/10/2014 10:22 am
...that's the shorter saddle to bar reach, so she's more upright on the bike.
I agree with Poly that bikefit is probably the best solution.
Posted : 12/10/2014 10:26 am
My GF rides bikes every day, always has..
She's got a fanny like a DM sole
I find if my saddle is just a little too high it puts pressure on the delicate area..
Tell her to try to see if she can move back a bit on the saddle, makes all the difference to me.
Posted : 12/10/2014 10:29 am
yunki, if she's on here she may well be your ex-girlfriend by now 😀
Yunki, I think that's an air sole 😆
Posted : 12/10/2014 10:49 am
My mrs went to the specialized shop at Fort Dunlop. They measured her sit bones and we picked up a ladies specific saddle at the right width. She loves it.
Posted : 12/10/2014 10:53 am
Where do you live?
Sure people will lend you a saddle to try.
WTB Deva you can borrow if you're anywhere near Calderdale/Rossendale.
Mrs S tried loads before settling on that one.
Posted : 12/10/2014 11:01 am
andymc06 - Member
If she reads that what she'll be calling him will sound similar...
Posted : 12/10/2014 11:14 am
Labiaplasty.
All the pro female riders have it done they just don't talk about it, all tipping the wink and knowing smiles. 😉
Posted : 12/10/2014 11:25 am
Ok.. From the context etc, I think I can work out roughly what a labiaplasty entails.. But it's made me really confused about what a rhinoplasty may be 😕
Posted : 12/10/2014 11:45 am
It's what you get in an African Greggs.
Posted : 12/10/2014 11:47 am
**** knows 😐
Posted : 12/10/2014 11:51 am
Rhinoplasty - that just stops you getting the horn.
Posted : 12/10/2014 12:02 pm
**** [s]knows[/s]nose. Fixed that for you.
Posted : 12/10/2014 12:07 pm
Have you tried numbing it?
Posted : 12/10/2014 12:45 pm
As in mmmm-num-num-num?
Posted : 12/10/2014 1:08 pm
In addition to the bikefit (saddle height/position) and different saddle options above already advised, this might sound numpty but please tell me she's not wearing undies under her shorts, that will not be comfy?!
Posted : 12/10/2014 1:09 pm
I haven't read all this sorry
But a female facebook freind said in the end it was bike fit not saddle fit
being to upright with no weight on her arms
Going from a Hybrid to a road bike solved the problem
Having had a saddle problem myself recently I 'd say load through seat bones
Posted : 12/10/2014 1:45 pm
bike fitting is probably the right solution, but make sure it's by someone who understands how to set a bike of for a woman. In particular the saddle should be tipped a bit down at the front to take pressure off. This helps a lot even with lady specific saddles.
Posted : 12/10/2014 1:47 pm
This article is interesting. [url= http://www.cervelo.com/en/engineering/ask-the-engineers/the-four-and-a-half-rules-of-road-saddles-.html ]Four and a half rules of saddles[/url]. [url= http://www.theguardian.com/environment/bike-blog/2014/aug/14/how-female-cyclists-can-combat-saddle-soreness ]Also this one.[/url] But, to be honest they don't say much different to above. It's mostly about finding the right saddle that works for you, and getting your bike fit right. The ISM Adamo saddles look interesting.
Posted : 12/10/2014 2:11 pm
Padded shorts can cause discomfort.
Posted : 12/10/2014 2:53 pm
My g/f swears by the Morvelo ladies bib shorts and says the pad is the best she's tried. Sadly Morvelo don't make bib tights.
Pain occurs at the front also.
Saddle wise we've been through Specialized Riva, and currently have a Selle Italia gel max flite.
Posted : 12/10/2014 2:54 pm
I don't believe that it's as simple as changing a saddle. Saddle and padded shorts need to work together. Some shorts have ridiculous amounts of padding and reckon that this can cause discomfort if the saddle isn't right.
My personal preference is for a leather saddle that 'gives' and has a cut-away shape. I've found that a minimalist saddle together with minimalist padding is the most comfy.
Obviously the angle of the saddle needs checking but it would be a good idea to check the set-up ie bar height and needing more/less spacers, does saddle need moving forwards/backwards. Is she actually sitting when she should be out of the saddle?
Posted : 12/10/2014 3:06 pm
 emsz
If she's using a saddle with a cut out make sure it's in the right place! They all seem a bit far back for me, and I think it put extra pressure on the front of my bits until i got rid of the one I had. I think it's trail and error though, I've just moved my saddle around until I found a place where it was best. And the right saddle makes a massive difference as well. I [i]can[/i] use SDG, but the best ever is my Cannondale Raven (which I don't think you can get any more.)
Endura make the best shorts for me, (narrow hips), but a pad that bunches up in the front can make it worse.
Posted : 12/10/2014 3:30 pm
Saddle down a degree, bars closer and higher. Abstinence.
Saddle choice is important, but fitting more so. Is her saddle too far back? Ladies need to take more weight through their legs when pedalling to relieve pressure. A saddle mounted with knee over pedal at 90 degrees is a good start.
Posted : 12/10/2014 3:53 pm
Could be the saddle is too wide and she's riding too far forward so that her legs can reach down. Mrs flap_jack went to a narrower saddle which cured all such ills. Now uses a Spesh Riva at 155mm, the sit-bone machine said 168 but the 155 works much better.
Posted : 12/10/2014 4:45 pm
With respect, I'd expect this is more likely to be part of the problem. Can you expect someone to take more weight through the legs when pedalling, as the legs will tire while riding? Suitability of bike fit and saddle are more likely to do the job. KOPs isn't really a starting point for good bike fit, more of a coincidental outcome or a basic guide for men on 73 parallel racing bikes.
She may well be tipping forwards too much. As someone said earlier, start with a more rearward saddle to get her weight back, more likely to give a neutral balance on the bike for comfort. Weight back via saddle position will mean she can raise the bar or bring it back (or both) without affecting her balance much, so the sitting position can be adjusted to be more comfortable.
Posted : 12/10/2014 4:50 pm
Thanks for all the answers everyone , some interesting points , I'll check her position on the bike etc and try a few more saddles I have lying about ...
Posted : 12/10/2014 5:00 pm
 Ogg
Other half is currently trying an adamo saddle getting on well so far, she had a Specialized Windie which was OK - compared to 'normal' blokes saddles which she described as like being hit in the **** with a hammer repeatedly...
Posted : 12/10/2014 5:17 pm
Do you have womens saddles lying around?
Posted : 12/10/2014 7:18 pm
As above - if the saddles you have lying around aren't women's they probably won't help. Have you tried any women's specific ones, or is she using your old saddles?
Where are you based? There will probably be someone local to you who can lend her various saddles to try...
Posted : 12/10/2014 7:30 pm
 Esme
[i]Mrs flap_jack went to a narrower saddle which cured all such ills[/i]
Err, would that be the famous [b]flapjackie[/b] by any chance?
Posted : 12/10/2014 7:57 pm
My wife used to get this even with a specialized body geometry female saddle. Every ride after 30/45 mins I could see she was getting uncofortable and she would complain about sore bits.
I recent got her a womens saddle from Edinburgh Bike Coop (not the huge sofa thing!) and it has made a world of difference, so much so that she nerver even mentions it at all on long rides.
This is combined with shorts with a proper womens pad and a liberal coat of sudocreme.
Posted : 12/10/2014 9:16 pm
Page 2 and nobody's suggested you offer to rub it better!
Posted : 12/10/2014 9:57 pm
@esme - well done for remembering the flapjackie thread - I was about to start searching for a link
Posted : 12/10/2014 10:01 pm
Keep trying different saddle positions.
The only time I've had too much pressure on - and therefore very sore - bits was borrowing a bike which didn't fit me particularly well. And then carrying a heavy bag on my back for 3 hours which maximised the pressure in all the wrong places. Not something I would like to repeat - took a few days to recover. Your gf has my sympathy.
Posted : 12/10/2014 10:08 pm
Does she get out of the saddle frequently as well? I know some of the ladies I ride with don't have great confidence technically, and tend to sit down over lumpystuff so its easier to get a foot down.
Moving around on the bike more standing on the pedals - on and off road - can help immensely.
Posted : 12/10/2014 10:22 pm
@yunki, with a little work that could be a Spinal tap lyric. I am also looking at the soles of my DM shoes right now but am not visualizing (thankfully !) 😯
Posted : 13/10/2014 10:22 am
 Yak
As above, position on the bike first, then saddle. Re saddle, Mrs Yak swears by Fizik Vitesse's (regular, not the tri-version). Normally v expensive, but currently £35 at probikekit.
Posted : 13/10/2014 10:27 am
Shedbrewed: My g/f swears by the Morvelo ladies bib shorts and says the pad is the best she's tried. Sadly Morvelo don't make bib tights.
Stick with the shorts then and get a pair of decent winter weight legwarmers.
Posted : 13/10/2014 10:30 am
This might sound like a daft question, what is she wearing to ride in. A decent pair of padded cycling shorts (worn without underwear, no offence to your gf but if she is a new rider, she may not realise that its far comfier, less chance of chafing and less seems to add to the pressure!), adjustments to ride position and finding a saddle (try looking for womens specific one) that suits should be what sorts this.
Personally, and it is a personal thing, I like Selle Italia saddles, but lots of others may not. Also, I don't like chamois cream, except for long road rides. Its a case of trial and error but hope she finds something soon!
Posted : 13/10/2014 10:40 am
Agree with Cinnamon Girl.
I have heard that the more padded the a£se is the more padded the saddle needs to be. And the same for skinny bums.
Try thinner padded shorts and less sofa like saddle.
Posted : 13/10/2014 12:31 pm
[img] http://postimage.org/ ][img] http://s30.postimg.org/ahum3we4x/Doc_M3.jp g" target="_blank">http://postimage.org/ ][img] http://s30.postimg.org/ahum3we4x/Doc_M3.jp g"/> [/img][/url] [url= http://postimage.org/index.php?lang=french ]heberger une image[/url][/img]
This one.
[img][url= http://s22.postimg.org/gb3dzp4c1/Dr_Martens_black_old_zpsf3b6726d.jp g" target="_blank">http://s22.postimg.org/gb3dzp4c1/Dr_Martens_black_old_zpsf3b6726d.jp g"/> [/img][/url] [url= http://postimage.org/index.php?lang=french ]hebergement d image[/url][/img]
Or the classic.
Posted : 13/10/2014 12:48 pm
Saddle height?
I find particularly on the road bike (although I'm a bloke) that having your saddle only slightly too high can cause real discomfort in the barse area.
I think it's because you end perched on the saddle rather than making proper contact with your sit bones.
Posted : 13/10/2014 12:57 pm
I had the same problem on both my road bike and MTB (so much so, thAt I used to wear 2 pairs of padded shorts on MTB rides!). It even used to draw blood! The problem disappeared when I put Specialized body geometry saddles at the correct width fitting on both bikes. I can go on all-day rides with no problem now.
Posted : 13/10/2014 1:45 pm
Another thought- check the saddle nose isn't pointing up, even by a small degree. I have my saddles with the nose pointing very, very slightly downwards. Makes a difference.
Posted : 13/10/2014 2:06 pm
Standard/men's saddles can't always be expected to work for women, who tend to have wider pelvises and sit bones because nature has designed them for tough, challenging work like carrying and incubating babies. Saddle fit certainly made a big difference for Mrs Digga who also visited a Specialized Concept Store (Stafford) to have this done.
Following that, bike fit is a pretty complex art and if saddle alone doesn't do the trick, you need to look at the angle, height and also bar height/reach. This could be [i]very[/i] hit and miss, so if you're short of time and your Mrs is getting short of patience, an appointment with somewhere that does bike fit might be a worthwhile investment.
Posted : 13/10/2014 2:40 pm
