I've taken apart the maestro suspension to change some bearings. When I put the bike back together the pivot at the top of the rear triangle / with the rocker isn't separated by anything. When I look at the 2012 trance in the shop it looks as though there is something separating the rocker and frame at that pivot point. Does anyone on here have a Trance X 2011? I phoned Giant and they said there should be something in-between the rocker and the frame at that point. I could swear there wasn't when I took it apart though! I thought about using the inner race of a pair of seized bearings as a bit of a spacer but finding it difficult to take a bearing apart.
Thanks
They have tiny washers , cone shaped. there is a thread week ago with exploded diagram.
[url= http://singletrackworld.com/forum/topic/anthem-xfox-rp2-shock-can-this-be-right ]Found it[/url]
These fall out when you unscrew the bolt.
Thanks for the link but that thread appears to be for an anthem X frame.
Spoke to Giant they're sending some of the "washers" out to me.
Turns out washers go at the top of the rear triangle but NOT for the rocker on the seatube downtube. Sorted
