Giant anthem x4 rea...
[Closed] Giant anthem x4 rear shock...trance rear shock
Can I fit the trance 5" travel rear shock in my anthem 4" bike ?
Posted : 16/02/2014 12:04 am
I cant see it working fella?..
Posted : 16/02/2014 12:08 am
Bugger, hoped that having the shorter travel on my anthem x4 frame I could have got away with the slightly longer piston shock compressed up alittle
Oh well, keep looking
Thanks for the reply
Posted : 16/02/2014 12:11 am
If it's the same length you'll probably get it in, but then you're presumably fitting more travel than the frame can cope with and may foul the wheel on the frame when it compresses
I didn't want more travel, it was more for it being a better spec shock - and at a good price.
Ohh well, thanks for the replies
Posted : 17/02/2014 9:54 pm
The trance and anthem have slightly different linkages so may run the same shock length
Posted : 17/02/2014 10:12 pm
Trance shock is 7.25"x1.75" 190mm x 45mm
Anthem shock is 6.50"x 1.5" 165mm x 38mm
Trance has an odd size...
I recently put a pushef fox float CTD on my anthem..
Can't grumble...its miles better than the stock RP2 it replaced.
Posted : 17/02/2014 11:44 pm
