Ghetto tubeless 24"...
[Closed] Ghetto tubeless 24" wheels schrader valve
OK, i have got some better tyres for my kids 24"bike, want to convert to tubeless. Rims are non-tubeless and use schrader valves.
I'm thinking 20" bmx schrader tubes for ghetto tubeless, but will the schrader vaves allow me to blast in enough air to inflate them?ย  Can i use 20" presta valves (with removable core) in schrader drilled rims?
Posted : 13/04/2021 3:10 pm
Just get schraeders with removable cores?
Or just use presta valve and not worry about it or buy the wee plastic inserts you can stick in a schraeder hole to make it presta sized
Posted : 13/04/2021 3:21 pm
oh i didn't realise there was such a thing as removable core schraders!
Posted : 13/04/2021 3:28 pm
All Schrader valves have removable cores so you can get way more airflow than with Presta valves, works well for plus and fat tyres! I did a ghetto setup on my Genesis and it's been fine.
Posted : 13/04/2021 3:29 pm
All Schraeder valves have removable cores. Much easier for tubeless than Presta. You can just pump them up at any petrol station and buy a can of Tyreweld for emergencies.
Edit. Damn, beaten by seconds.
Posted : 13/04/2021 3:35 pm
Also ghetto tend to sit much tighter between rim and tyre, so very rarely you need air blast.
Normal track pump and soapy water did me ok. I think only once I really struggled on ghetto conversion. That was some old and pretty baggy tyre.
Cheers!
I.
Posted : 13/04/2021 3:41 pm
 Tim
Few layers of gorilla tape, prick a small hole through at the valve hole and then force a tubeless valve through. Worked for me in the past as the seal on the valve locked onto the valve plus the mass of tape sealed it.
Posted : 13/04/2021 10:07 pm
 igm
Probably get a valve free by scrounging at Kwikfit too 😜
Just use a BMX tube.
Posted : 13/04/2021 11:29 pm
