Getting to the deep...
[Closed] Getting to the deep 10mm socket in new Rebas.
4 Users
What do you use? A long reach 10mm socket?
[url= http://www.ebay.co.uk/itm/Sealey-Long-Reach-Spark-Plug-Socket-with-Tommy-Bar-10mm-/281012889661?pt=UK_Measuring_Tools_Levels&hash=item416dac683d ]Something like this?[/url]
Wally.
Posted : 28/11/2012 6:43 pm
If they are anything like the SID's I had on a bike a couple of years ago, it doesn't need to be quite that deep. [url= http://www.ebay.co.uk/itm/10mm-Deep-Hex-Socket-3-8Drive-/251189856207?pt=UK_Hand_Tools_Equipment&hash=item3a7c1507cf ]Like this[/url] should* be fine
*though I'd suggest you measure how long it needs to be and check in a proper motor factor.
Posted : 28/11/2012 6:52 pm
a long series 3/8" drive 10mm socket will do it. cheap off ebay, you wont be leaning on it.
Posted : 28/11/2012 6:54 pm
You may find that's to fit a 10mm threaded spark plug, not a 10mm AF nut. Better off with a deep 1/4" drive socket and extension.
http://www.ebay.co.uk/itm/Sealey-WallDrive-Socket-10mm-Deep-3-8-Sq-Drive-/290793470449?pt=UK_Hand_Tools_Equipment&hash=item43b4a439f1
deep socket is a better description then long, sorry.
as coatsey says, a 1/4" should do it too
Posted : 28/11/2012 6:56 pm
Shirley 3/8" or 1/4" depends on what your socket set is?
(making an assumption here that the OP already [i]has[/i] a socket set of course.)
Posted : 28/11/2012 7:14 pm
Many thanks got the one from the link - I have both 3/8th and 1/4 drives.
Posted : 28/11/2012 8:35 pm
