Getting rid of my o...
[Closed] Getting rid of my outer chainring, anyone else done this?
I'm considering getting rid of the outer chainring on my Stumpy, I can't remember the last time I have used it on a ride, and have bashed it a few times on logs/rocks etc.
Has anyone taken their outer chainring off and replaced it with a bashguard or something similar? Sods law states that as soon as I remove it, ill need it on some sweet descent, or never bash the bashguard.
Any thoughts?
Posted : 26/01/2011 11:24 am
The subject was quite recently hacked over on here;
http://www.singletrackworld.com/forum/topic/twin-ring-whats-the-pros-and-cons-over-triple
Posted : 26/01/2011 11:29 am
Yeah, I went to a 36/22 and a lightweight bashgaurd. Normally always ride in the middlering now, just dropping to the granny for super steep stuff. 36 gives me a bit of top end still. Never run out of gears so far but I don't do much road stuff. I reckon the aerodynamics of a wide bared MTB would be the limiting factor on the road rather than gearing though.
Posted : 26/01/2011 11:30 am
I did it as my BB is quite low & I kept getting stuck on logs (or at least the bike did - I generally went OTB). The only time I really used the 44t was on the road to & from a ride, so I've not missed it off road, although I did increase the middle ring to 34t. Replaced the outer with an E-thirteen bash.
If you don't use the outer on decents, then go for it. Just remember to adjust the limit screw on your front mech.
Posted : 26/01/2011 11:32 am
As above really, I run a 28T / 36T up front on my 2004 Enduro and haven't missed the big gear up front.
I got fed up with having to replace big chainrings at £35 a pop...
Posted : 26/01/2011 11:37 am
on my xc bike (kinesis maxlight) i have no granny ring, and use the outer loads, but on my specialized sx, the outer has gone.
depends where and what you ride really i'd say.
on my sx, i removed my outer ring, with a view to getting a bash, but my local shop didnt have the right size in, so i ground all the teeth off smooth, with a bench grinder, and made my own bash gaurd, so that i could ride that weekend, looked smart enough, and let me get out on my bike that day!
Posted : 26/01/2011 11:40 am
yeah 22/36 and no bash here as I found with the extra clearance of no big ring I stopped bashing rings much anyway
Posted : 26/01/2011 11:41 am
yeah the big chainring is always the expensive one aint it.... my son gave me his RaceFace Bashring -looks good now... 😉 i never used the outer ring...it got bashed a couple of times by rocks..
Posted : 26/01/2011 11:42 am
 DT78
I use 26/36 on my XC bike. I haven't bothered putting a bash on yet and haven't had any issues with losing the chain.
Posted : 26/01/2011 11:45 am
Yes, and changed the 32 for a 36. The bash ring saved me from what would have been a really nasty injury just after Xmas (it's one thing breaking a leg but another thing having to also deal with a huge wound underneath a plaster cast). My bike has a low BB and I now ride much more positively at logs which are just that bit too tall.
Posted : 26/01/2011 11:46 am
22/36 here. No bash on the solo, big chunky bash rings on the tandem
Posted : 26/01/2011 12:16 pm
 D0NK
yep ditched all mine, 36 on my (not very) "fast" bike, 32 on the rest. Tarmac and downhill fireroad can be a bit spinny but who cares about those bits?
Posted : 26/01/2011 1:19 pm
