So, if I tighten my seat clamp (Hope) enough to stop the Reverb slipping down then it sticks and won't return to max extension under its own steam.
I'm guessing this has something to do with the fact that the Blue Pig X comes with a shim to increase the seat tube diameter to 34.9 as the wall thickness of the steel seat tube matched to a 30.9 internal dia adds up to some weird number.
Anyone figured out a solution? I was thinking of fitting an external shim that would sit between the seat tube and the reverb collar. What do you think?
Chris
Crushing Reverbs = BAD!!
Where does the Shim go? is it outside?
Can you get the correct size clamp? I use a non QR one now I have a dropper which may increase your options.
Yeah, shim is on the outside and I'm using a Hope non QR clamp.
What about some sort of thread lock/carbon fixing compound instead of grease?
Sure am not keen on crushing the reverb and no mistake.
Either you need to tweak the settings or you are already crushing it.
Probably some Carbon Assembly paste would help but not used it on a non carbon interface.
Having the same issue on the missus LTc double Peril of crushing reverb and frame
Think I might just swap it out and sell the Reverb.
I have a KS Lev, and the instructions say NOT to use grease for installation. They say to use either carbon paste or anti-sieze. Carbon paste may allow the seatpost to stay put with a lot less force on the seat clamp.
Edit - sell the dropper? Are you crazy? ๐ฏ
Probably some Carbon Assembly paste would help but not used it on a non carbon interface.Having the same issue on the missus LTc double Peril of crushing reverb and frame
Your missus has an LTc?! What on earth does that mean you ride.......a gold plated version bonded by angels?!
I use copper slip on the LEV in my piglet and that seems to work. You need something that doesn't lubricate but also stops the aluminium post binding with the steel frame. As much as a little slippage is annoying its not nearly as bad as your expensive seatpost welding itself stuck!
JoeG - Member
Reverb instructions say exactly the same thing, but it appears the OP hasn't bothered looking
Yep she has the ltc I have a heckler she just treated herself.
Yep anti-sieze not grease will men it stays put with out the need for over tightening the clamp
Weell, the OP is not one for reading the instructions on anything!
Thanks for the advice, I will remove the grease forthwith.
Chris
Thomson seatclamps are also better at getting tight with not as much force.
Carbon paste - job done.
Did it on my Solaris and it worked a treat ๐
I tried a Thomson clamp but it had insufficient clearance to fully tighten up; hence the Hope.
Now fitted with carbon paste. I shall let you know!
C
I had this problem with a Gravity Dropper on my Soul with a Hope QR. Swapped the Hope for a reversed Thomson clamp and it's been perfect ever since.
