getting over a fear...
[Closed] getting over a fear of jumping???
i have alittle problem with jumping!!
ive been riding now for ages(20 odd years!) and have never been able to jump properly !!
im ok with drop offs and the like but put a set of doubles in front of me and it all goes tits up.
i either end over the bars as i land in the dip front wheel first or i go over the bars as my rear wheel is getting caught in the dip too!!
ive tried doing it faster and just end up bottling it and messing it up.
im ok with single jumps where you land flat but i just cant bring myself to do doubles!!
any ideas??
cheers
steve
Posted : 18/04/2010 3:52 pm
get good at tabletops first...
Posted : 18/04/2010 3:53 pm
A double is just a tabletop with the middle cut out. Learn to jump them and then move on.
Smoothness is key, relax or you'll dead sailor.
Posted : 18/04/2010 3:55 pm
im even messing up table tops!!
when i do the "jump" i seem to be going off at an angle and landing funny which is pitching me off the bike!!
Posted : 18/04/2010 4:03 pm
skills course mate? somethimes you need someone to actually show you how to do somthing point out what you're doing wrong......well I do!! 😆
Posted : 18/04/2010 4:15 pm
I ride round them 🙂
Posted : 18/04/2010 4:26 pm
look where you're going to be landing and stop thinking the world becomes a straight line from the lip of the jump onwards, thats what used to mess me up! (I doubt that helps anyone! 😀 )
Posted : 18/04/2010 4:37 pm
We offer skills sessions covering all you will need to know on jumping and pumping, its hard to convey in few words through forums but we'd be only to happy to help, look us up at http://www.mtbskills.eu Most of our sessions are run at Mabie Forest 7stane's trail but we can deliver bespoke sessions at a location of your choice. Feel free to drop me an e mail - ss01mbc@mac.com - practice your speed control (do I need to go faster or slower to match the feature), manuals and bunny hops as they are key components when it comes to jumping. Good luck and have fun. Clive.
Posted : 18/04/2010 5:33 pm
Go to somewhere like Redhill Extreme where the jumps progress in size and you can roll them/jump/do what you like on them.
Posted : 18/04/2010 6:06 pm
 jedi
you can do drops but not jumps? same technique basically.
pushing into the kicker is the same as pushing into a drop
Posted : 18/04/2010 10:47 pm
Sounds like you might be yanking the bars which will put you off balance.
Posted : 18/04/2010 11:08 pm
 jedi
pulling the bars or pedals with your feet it a no no!
Posted : 18/04/2010 11:14 pm
you're not alone! I think it's just more speed + balls and disengaging yer right thinking brain.
Posted : 18/04/2010 11:19 pm
pulling the bras jedi!!!!!!!
go on a skills course and find a tabletop to practise on
Posted : 18/04/2010 11:21 pm
 jedi
balls is never the answer!
Posted : 18/04/2010 11:24 pm
A double is a table top with the middle cut out. A table top is a big hump with the top cut off. Practice on a big hump and get used to the bike going light over the top and work up from there. The big hump emulates exactly where the bike should be through the air. Worked for me anyway.
Posted : 18/04/2010 11:35 pm
at lee quarry today, i tried a lot less harder than i'd previously been doing and found myself clearing one of the smallish tables fairly easily.
Posted : 18/04/2010 11:37 pm
"balls and disengaging yer right thinking brain."
Don't do that or you'll be maimed 😉 "Balls" is just another way of saying "I don't know what I'm doing but I'm doing it anyway". Even if it does well it's not "doing it" it's "getting away with it" Figure out how to do it instead then you won't need so much balls.
IMO 😉 I won't lecture you on skills, tbh I'm not in a position to for pushbikes, I'm not that great but I used to ride motorbikes by balls alone and I'm quite lucky I didn't pay for it I guess. These days I ride by skill and brain, I don't go quite as fast but then I don't end up in as many ditches. And getting away with it never taught me a thing.
Posted : 18/04/2010 11:47 pm
 jedi
jumping is very easy and the same as drops
Posted : 18/04/2010 11:49 pm
only if your doing drops right to start with
Posted : 19/04/2010 12:04 am
Put a peice of wood between the doubles, it's now a table top. Do it. Now remove the wood.
Posted : 19/04/2010 12:23 am
I used to be a bit like that.
Realised that it wasn't the jump that scared me, it was hitting the ground... obvious I know. But, then you can work on jumping by really checking out your landing point and ensuring that it's good. Then the jump is just flying without wings!
Posted : 19/04/2010 12:54 am
get a good skills coach to take you through the technique... you will get better much quicker than trying to learn by yourself.
Like others have said it sounds like you are trying to pull up on bars/pedals and it also sounds as if you are too tense when in the air.
You probably need to learn how to pump the bike correctly. Getting air should be coming from pushing the bike into the ground. Think like bouncing a ball. The harder you bounce into the ground the higher the ball goes.
Once you have your pumping sorted you then need to learn where and when to pump. Once you have timing it is a case of finding somewhere with a bunch of tabletop jumps that start off small and progress through to bigger. Get your technique dialed in on the jumps you are comfortable with (making sure you confident on the small ones and can relax will give you a feel for what you should be doing). Once you have the smaller table tops dialed, then move up to slightly bigger and bigger ones. When you want to move to gaps, you probably want to go back to a bit smaller than the table tops just because they are a little scary.
Easiest way is to find someone good to teach you this stuff...
Posted : 19/04/2010 3:53 am
Reading your comments it sounds to me like you're pulling up, and pulling unevenly, as you hit the jump. This is a common cause of nose-diving over jumps, often leaves you badly set up for landing, and the pull makes a twist more likely than a smooth pump.
By pump i mean you should be pushing evenly and snappily into the face of the jump - the rebound of your front wheel into the air as you do this is what give smooth and controlled lift.
You say drops are ok but what may be happening is the exaggeration of minor problems in your drop technique - again this often happens when you are under pressure (ie hitting a jump knowing you're not sure about it).
Do you have a video or small camera that shoots video? If you do then - if this is useful for you - get a friend to shoot you doing a couple of jumps and drops, put the footage on youtube, and email me the link at chris@cycleactive.co.uk We coach this stuff an awful lot and it'll only take a minute or two to see what you're doing and make a couple of more meaningful suggestions.
Hope this helps.
Chris
Posted : 19/04/2010 8:00 am
I really need to get someone to show me then. Every time i do a drop off i pull up on the bars. Obviously doing it wrong. Need to save up my pocket money and get a sesh with Ed booked I reckon.
Posted : 19/04/2010 8:14 am
 jedi
soobalias, you know it 🙂 🙂
Posted : 19/04/2010 8:42 am
 tron
I learned to jump the other day, with the aid of the speed humps up the road and a howto article on Bikeradar. I've always been one for pulling up on the bars, getting the front wheel up, twisting it, landing in bit of a mess etc.
As soon as I realised that I needed to push down into the ramp and practiced somewhere without trees to crash into and lots of repeatable ramps, I got it sorted very quickly. I'd recommend it over trying to learn on the trai, where there are lots of hard things to crash into, your mates watching and the jumps aren't uniform and don't always have nice easy landings.
Posted : 19/04/2010 9:08 am
For a drop off from a flat piece of trail, though, don't you have to pull up on the bars? I get that you should 'scoop' the bike up over a jump by pushing into it, but for a drop there's nothing to really push into on the trail - if you just rode straight off wouldn't you risk a complete nose dive? Just asking as a beginner who's trying to sort basic drops out.
Posted : 19/04/2010 10:23 am
Eh? You push into a drop?
Posted : 19/04/2010 10:33 am
Renton, you are not alone, I am here typing with a dislocated shoulder and a badly mashed wrist, face and leg after completely cocking up a set of doubles at Glentress yesterday. Long drive home to London OUCH !!
Still could have been worse.
Me ? I'm going around them next time. Pushing down and using rebound seems like the easiest thing to say in the world, but if (like me) you just don't get it.....you're stuffed !
Ride safe and keep your wheels on the ground there fellas !
Too old to hurt myself this badly......again !
Posted : 19/04/2010 10:38 am
Unweight, pull up on bars to keep level, push down with heels when nearing landing, . . no?
Posted : 19/04/2010 10:39 am
WOW I know something
For a drop, kurbs are a great starting point, you push down before you reach the lip
The physics is simple as you push down you increase the force between the bike and ground, when you stop pushing this force pushes the bike up just before you go over the edge
You can go off a curb pulling on the bars but it doesn't work well
Posted : 19/04/2010 10:41 am
Never been a problem for me, just pull back and lean back a little unweighting the front?
If i do do it I've never noticed that I do, I generally just unweight the front end and allow the rear to drop as it wants, then scissor action down as the rear lands, or on a transition landing I just let the front drop to match the slope.
Anything else seems like pre-jumping the drop, which would just add height to it? I have no problems doing it from stationary on the rear wheel, I've no idea why I struggle on the trail!
Posted : 19/04/2010 10:52 am
is it easier to learn to jump on a hardtail or a full sus bike, only asking as it's something I need to sort too.
Posted : 19/04/2010 11:00 am
On the confidence thing I'd say mine has taken a dent from spending the last hour and a half teaching a student with a scape down the their whole face where they failed to clear a jump
Posted : 19/04/2010 11:15 am
Riding drops and jumps on the trail requires a much different technique from trials style stationary drops. You basically do the first part of a manual as you approach the drop/jump, pumping it. The faster you go the easier it is.
Posted : 19/04/2010 1:01 pm
is it open yet? Its only up the road from me and I fancy having a go. I, too, have some serious wheels-oof-the-ground issues
Posted : 19/04/2010 1:40 pm
The wee book "Essentials" by the girls who set up The Hub at Glentress (Emma and Tracy)I think explains it rather well. I picked up from it that you want to shoot as far upright and forward as you can by pushing down on your bars and pedals. You then get masses of height without needing to go very fast; much more controllable."Good Game" at GT is ideal to practice on IMO.
But doubles still give me the willies.
Posted : 19/04/2010 5:40 pm
 jedi
the bike you use to learn on doesnt matter. you NEVER pull the bars.
(only when cleanly in the air you can)
never press down with your legs to land.
Posted : 19/04/2010 7:39 pm
Lot of people workin on jumps...
@Lowey - without wantin to be too pushy, check out the courses we have on jumps, pumps and drops at www.cycleactive.co.uk or get a private day of tuition if you prefer.
@tron - great! I wrote that article so I'm glad it worked for you.
About pullin up, or pushing "down". Neither is the answer. Think about having a bouncy ball and droppin it onto a ramp - it bounces off forwards. Now push it hard down onto the ramp - it bounces further. reverse that process and that's what your tyre does - push it into the face of the ramp and the harder you push, the higher you go. Pump=Push but it's a short, snappy push.
As for pushin down, if you do that a lot of your energy is soaked up by the forks, especially if they're 5 inches plus and well damped. So you push forwards and just a bit down so the energy is instantly turned into lift.
Goin off drops is similar. This time you definitely push forwards and down into the ground, and the instant, smooth rebound from the tyre (not the forks) gives your lift.
@younggeoff - As for the bike choice thing, you definitely get more height and quicker response from a hardtail because much less of the pump from both hands and feet gets absorbed by the bike. However, the flip side of this is that it responds much more quickly, so is maybe a bit harder to control than a full sus bike.
But you can perfect the technique on any bike...especially with a good coach....check out the courses run for us by Rich Barnard, Jon Chalmers and James Richards at www.cycleactive.co.uk We cover Cannock, the Lakes, Malvern and Ae Forest.
Chris
Posted : 19/04/2010 9:08 pm
I did one of the cycleactive jumps drops etc courses at FoD with cycleactive, must say it helped loads. 🙂
Posted : 19/04/2010 9:14 pm
Build your own. That way you can start with something that's just a fraction out of your comfort zone and keep getting bigger. Worked for me for both kickers and drops.
Posted : 19/04/2010 9:19 pm
once you have been shown the right way. After a skills day with Jedi I finally got it and every ride now builds on the core skiil required to build up to bigger jumps slowly and safely.
Posted : 19/04/2010 9:21 pm
Wish I could afford a skills course, bit pricey for me even if they are good value.
Posted : 19/04/2010 9:46 pm
Ditto Coffeeking 🙁
Posted : 19/04/2010 10:39 pm
I am a bit like the OP in that I adopt the adage that jumping is easy it is the landing that hurts ❗
Like the OP I to have been riding for over 20yrs and do not see the need to get into this jumping malarky
Doing a dynamic risk assessment and not wishing to break myself again means I tend to keep my wheels on the ground wherever/whenever possible whilst still enjoying myself.
Even on a skills day there must be a risk that if/when it all goes wrong it can/will all end in broken bones and tears.
I have watched many a jump session and DH race but have also witnessed broken bones 🙁
Posted : 19/04/2010 10:42 pm
Yup you definitely sound too tense to jump there 🙂 You've already convinced yourself you're going to fail.
I found the tip to keep wrists & heels down when approaching a jump makes everything a bit more predictable. I'm still crap though
Posted : 19/04/2010 10:56 pm
the same can be said for crossing the road.
Posted : 19/04/2010 11:02 pm
For drops I found the tip on bikeradar DH to 'keep your hips vertical relative to the BB' makes a big difference too.
Posted : 19/04/2010 11:04 pm
 jedi
trektser, the risk is minimised through certain controls i use
Posted : 19/04/2010 11:33 pm
Whoever asked about redhill, it is open.
Posted : 20/04/2010 12:17 am
@duncan - thanks, that was james richards, right. he's also running some things in cannock this season, as well as his home turf of malvern hills.
@trekster - the risk of injury on a course is very, very small. the whole point of good coaching is that it is progressive, covering the core techniques in a safe and easy-riding environment then building up from there. the rate of progress to more advanced terrain is set by the progress of the clients, and the instructor's ability to gauge that progress, correct their techniques and move people forward safely.
@those people who cannot afford it - a day of skills coaching costs 95 pounds from us, and i'm sure similar elsewhere. Or book James in Cannock with a group of mates and it gets cheaper than that. At some point you cannot invest any more in your bike to make you better - you have to go to the source and invest in yourself. It's well worth it.
Chris
Posted : 20/04/2010 7:12 am
 jedi
muddyarsetony, high5 🙂
Posted : 20/04/2010 8:41 am
spent a fair bit on a course with jedi. only saying to someone yesterday that is was amazing value. would have paid for only half what i learnt.
the value is not in the 4 hour course but in the riding afterwards.
I spent £100, i've ridden 100 miles since; £1/mile.
dead cheap.
Posted : 20/04/2010 8:55 am
Yeah, any other sport and people wouldn't think twice about being taught!
Posted : 20/04/2010 9:23 am
Me and my mate did an afternoon with Jedi last Friday. At no time did I feel I was being forced to do stuff outside of my comfort zone. When we were learning new skills or re learning ways to do stuff, Jedi made sure it was on terain we were happy with. He is good at putting you in situation where you can concentrate on the skill not where you are doing it.
Thats not to say we didnt ride anything interesting on the contary the trails were a lot of fun with drops, jumps and berms etc and some nice loose natural stuff.
The only jump that I was uncomfortable with, was a gap jump that we looked at at the end of the day and he made it quite clear that we had the skills to do it, but it was entirely optional if we were comfortable with it.
I would deffo recomend it, both me and my mate ride all over the place. Maybe not the best riders in the world but we are pretty comfortable on most terain, but we both got a lot out of the session. By the end of the day we were both riding smoother and a lot less sketchy in some sections 🙂
Best bit of it though, was we had a right laugh, riding my bike with my mate and Jedi on a warm dry day, it does not get much better 🙂
Bazzer
Posted : 20/04/2010 9:42 am
 jedi
bazzer, thomthumb high 5. dont forget keep me informed of your progress as i said.
Posted : 20/04/2010 10:28 pm
jedi - Member
Recognise this Chris?
An 8yr old girl member of my club!!!
As a swimming teacher, a trainer for various bits of kit at work I understand where you are both coming from.
I still have the fear factor/lack of confidence(too old) which I doubt any coaching could ever overcome.
eg a mate of mine who does DH uplifts cannot understand why I am faster than him on any normal DH section yet will not do DH.
reasons;
1) I do not like jumping
2) cannot afford a DH bike and all that goes with it
3) He is currently suffering a really bad shoulder injury, another friend has severe facial injuries, another broke hos neck, another broke his back etc, etc....
Posted : 20/04/2010 11:21 pm
 jedi
oh god, i would never allow that to happen. tell me that wasn't a coaching day!
i don't push anyones limits. trekster, there's nothing wrong with having fears
Posted : 20/04/2010 11:44 pm
I count [s]6[/s] [s]7[/s] 8 issues with the picture of the girl riding that section, all of them negative, with her weight being forward of the BB being probably the biggest one apart from the likelyhood of a washout into center stages gonads.
Posted : 21/04/2010 12:00 am
jedi - Member
Not a coaching day and her dad is the guy on the right. She is just brill on a bike. There are quite a few really good young uns.
My motto is "if in doubt, bail out"
Given my fear of landing(not jumping)how can that be overcome?
btw, chatting to EuroClive the other day(Forth)We ride the same trails but at different levels ❗
Posted : 21/04/2010 12:37 am
 jedi
confiedence builds as the physicality becomes ingrained.
we ride the same trails? we all do. it's all singletrack 🙂
Posted : 21/04/2010 9:39 am
I made a bit of an effort last summer to learn to jump.
Getting my head around the "push in to the face of the jump" was the biggest change in what I was doing. Quite happy on tabletops now, and just warming up to doubles.
Cwmcarn freeride section on the xc trail is a good spot for progressing from small to medium sized tabletops.
Posted : 21/04/2010 10:11 am
Renton
are your pedals level when you take off?
Apologies if thats already been pointed out, i only skim read the other posts.
Posted : 21/04/2010 10:45 am
Trekster I would say have a go with a skills session. You have nothing too lose apart from a couple of quid.
Its possible to overcome fear by starting very small and working up. You can start practicing drops on a curb. Once you have that sorted you can move up with confidence.
I never thought I would get into the whole jumping DH thing and although I am not very good I do enjoy it now. It also improves your trail riding a lot too.
Try going out in the road for an hour and practicing on curbs. If you ride from your door to trails, practice on the way there and back hopping on and off curbs etc.
Bazzer
Posted : 21/04/2010 10:48 am
95 notes is nothing guys. really genuinely nothing. think of golf coaching that people spend years at all for what £20/hr maybe? so thousands of pounds a year.
mx coaching days are all well over £100 IIRC, plus fuel etc. etc.
if the fella is as good as he says he is, then id go for it!
*edit - sorry i mean as good as everyone says he is...
Posted : 21/04/2010 10:57 am
 jedi
who me?
Posted : 21/04/2010 10:24 pm
Cheers bazzer
Part of the problem is a dodgy ankle, knees and bad back. Advised 20odd yrs ago to give up impact sports!!!! As said before the jumping is the easy bit, landing might not be so easy if either of the dodgy bits give up 😕
Posted : 21/04/2010 10:32 pm
 DT78
Tried to teach myself to jump last year, after 4 weeks or so I was progressing to small doubles, though I was regularly nose diving. Then I managed to hit one wrong, get sideways and land on the side of the transition breaking both wrists...I haven't been able to get my confidence back since.
Definitely would not recommend JFDI'ing.
Think I might go the skills course route this summer 🙂
Posted : 21/04/2010 10:59 pm
 jedi
my coaching session today led into jumping.
Posted : 21/04/2010 11:08 pm
i cant even bunnyhop that much ,is there much hope for me , i also suck , big stylee
Posted : 21/04/2010 11:11 pm
 jedi
some peoples riding doesnt include jumping. mtbing is a wide kaleaidoscope (sp) of colours
Posted : 21/04/2010 11:42 pm
This guy seems to give the best tips for jumping technique, but he has probably had years of practise.
Posted : 22/04/2010 6:17 pm
love the video - ride fast, sit down with one pedal up and one down, line up your skateboards and be 6 years old. taught my kids to jump smoothly when they were 5 and 7 on a little dirt ramp we dug in my dads garden. doesn't have to be high or scary to look at basic techniques - in fact, if you start really small you get rid of all the nerves that can make you stiffen up. Then my little lad decided to show off his regular jumping skills leaping for a bar on the climbing frame at school and broke both bones in his right forearm when he missed - crazy.
chris@cycleactive
Posted : 22/04/2010 7:41 pm
