Get your bike check...
[Closed] Get your bike checked out, regularly! - broken freehub content.
So one of my mtbs had loads of creaking sounds coming from the shock bearings and bottom bracket area. I dropped it in to the lads at my lbs to try and figure out what the problem was. On top of needing a new bottom bracket, it turned out that my freehub was cracked in a few places! I was shocked to hear but went in and saw it with my own eyes. Not even sure how that could happen tbh! But if I didn't get the bike checked out for the creaking sound then it could have gone horribly wrong as I would have blissfully ridden the bike this weekend at the Scott mtb marathon.
๐Ÿ™‚
Posted : 27/06/2014 5:56 pm
make & model? I just discovered same on my Shimano m785 hub last week - awaiting warranty response after sending photos to supplier
Posted : 27/06/2014 6:02 pm
It was a Wheeltech 142x12mm hub on DT rims, came stock on my Rocky Mountain Element 950, 2012 model.
Posted : 27/06/2014 6:13 pm
Or you could just check out your bike yourself regularly..
Posted : 27/06/2014 6:51 pm
[suspicious]Do you own a bike repair business? [/suspicious] ๐Ÿ˜†
Posted : 27/06/2014 9:31 pm
Not everyone knows how to, or has that inclination.
Posted : 27/06/2014 10:35 pm
Its not rocket science its a push bike. My Shimano freehub has recently cracked in half M785 in under 70 miles. Madison have them in stock and not an issue according to them. ๐Ÿ˜ฏ
Posted : 27/06/2014 10:47 pm
It wouldn't go horribly wrong, you will just lose the ability to move forward.
Posted : 27/06/2014 11:06 pm
I check my bike pretty frequently. I'll stress test it for about 3 hours about 3 times a week....
Posted : 29/06/2014 11:38 pm
It's not really something that you'd first discover by "checking out" though.
You'd more likely suffer bad shifting, notice a change in tone from the freehub, poor pick-up under drive, or worst-case scenario - total failure.
Posted : 30/06/2014 8:58 am
This. I had (a Tune) one fall apart on me in a race. It slipped a couple of times under hard pedalling, then the shifting went skewy for 30 seconds or so, then it started making a horrific noise under any load. Took wheel off and cassette and bits of freehub body fell off. Hardly fatal.
Advice is sound though.
Posted : 30/06/2014 9:24 am
Either or!!
Posted : 30/06/2014 10:49 pm
for once no once has mentioned superstar ๐Ÿ˜€
Posted : 30/06/2014 11:06 pm
i think the front end is probably the first most important place to check.
Posted : 01/07/2014 7:59 am
Cheers for the heads up
I will be removing my cassette after every ride
๐Ÿ˜†
Posted : 01/07/2014 8:50 am
I had a freehub utterly die on my road bike once. Had to zip-tie the cassette to the spokes and make an ersaztz fixed gear to ride the 25 miles home. Lucky I had some zip ties really.
Posted : 01/07/2014 1:55 pm
Zip ties fix everything!!!
How do cracks even form in the freehub though? Didn't think it would be exerted to enough force.
Posted : 01/07/2014 3:21 pm
Dunno, aluminium ones do get pretty chewed up though. Having said that it's not a problem I ever had - the pawls died on mine.
Posted : 01/07/2014 10:14 pm
