Genius needed! (gea...
[Closed] Genius needed! (gears help required)
Hi,
im just trying to set my gears up and im having trouble - something which doesnt happen very often!
basically ive got a new chain, a chainset thats less than 200 miles old and a cassette thats done maybe 250 miles. i have set it up so its shifting nicely - its just that when im in the hardest gears the chain seems to slip when i put the power down. the shifting is set up fine, like i say i get all gears nicely.
i just need to know whats causing the chain to slip/skip when im in the hardest gears. do i need a new cassette or is the chain the wrong length or what?!!
its driving me mad, please help!
ta
Ben
Posted : 16/01/2010 5:05 pm
it does sound like a worn cassette
Posted : 16/01/2010 5:06 pm
Almost definately a mismatch between the used and new parts. Stick your old chain back on and keep the new one until your cassette is knackered.....
Posted : 16/01/2010 5:11 pm
wot PP said
Posted : 16/01/2010 5:14 pm
How many miles had the chain done before changing? If it was older than the chainset then the 200 / 250 miles won't matter, the old chain would have accellerated the wear and the tooth profile of the whole chainset.
Posted : 16/01/2010 5:15 pm
the old chain is in a bin in hope - its the 4th time it snapped in two rides. it was reeeaaaaaaaly old.
looks like a new cassette's needed then?
Posted : 16/01/2010 5:17 pm
thread hijack -
pp, what is your website with all the clever fork servicing stuff on it? I' er.... need some advice! *puts down hammer and walks away from semi-dis-assembled rebas*
Some info here will help:-
[url= http://fagan.co.za/Bikes/Csuck/ ]Chain Wear[/url]
Probably new fronts too.
Posted : 16/01/2010 5:19 pm
Stick it out for a bit, it will wear in if the cassette is that new.
I have it happen some times when I hevnt changed the chain until it has significant stretch.
May take about 100 miles or so, just take it steady in the gears it jumps in.
Posted : 16/01/2010 5:24 pm
