Genesis IO ..... Ok...
[Closed] Genesis IO ..... Okay with 120mm travel?
Being reet lazy with this ...... ๐Ÿ˜ณ
About to build up an IO with a set of Recon solo air forks set at 120mm travel.
I could adjust them to 100mm but I am being lazy and I have only just tripped them.
The frame looks well enough built to take the extra 20mm but I guess geometry will be a bit "out".
Anyone else run a longer fork on their IO or IO ID?
Posted : 09/02/2012 5:32 pm
I had a Reba U-Turn on my iO and ran it at 100mm. Anything about that felt too high and slack for me. Your results may vary.
Posted : 09/02/2012 5:35 pm
Dependent on model year I believe Genesis say you can run up to 130mm (Think that was as of last year) - before that I think they were warrantied for 120mm, should be in your owners manual/Genesis site. It'll slacken your head and seat angle by a degree, so descending will be easier, climbing wondereyer..
If you drop the stem that'll compensate for the 20mm rising of the handlebars from the longer fork.
Posted : 09/02/2012 5:45 pm
My IOID came with a 100 mm fork as standard and I cannot image 20 mm unsagged more will really be that significant
Posted : 09/02/2012 5:46 pm
Cheers all.
Frame is way out of warranty.
Might give it a go.
Posted : 09/02/2012 7:04 pm
