Gearing advice
[Closed] Gearing advice
Hi all, Im relatively new mountain biking and new to the forum so please be gentle about my questions ! I currenlty ride a 2011 voodoo bantu which isnt an expensive bike but I ride on a tight budget. The Bike is currently 24 speed but I have noticed I rarely using the largest front chain ring and my 8 speed cassette is getting worn. My plan is to convert to a 2x9 set up but I want to do it as cheap as possible. I know ill need a 9 speed cassette and shifter but will i be able to use the 8 speed derrailiuer (crap spelling)? I presume if I put a 2 chain ring crank up front the 3 speed shifter will be fine? Any help or info will be very much appreciated, thank you peeps.
Here is a link to the bike:-
http://www.voodoobikes.co.uk/bikes/mountainbikes/
Posted : 24/08/2012 1:57 pm
The rear should be fine, the front may need a new derailleur depending on whether you use a double specific chainset, or a converted triple.
Posted : 24/08/2012 6:58 pm
Ah cool, thanks for advice its much appreciated 🙂
Posted : 24/08/2012 7:12 pm
Keep the cranks you've got, & use Deore stuff to go 1x10 with a 36-11 cassette. About £100...
Posted : 24/08/2012 7:30 pm
