Gear ratios; rear c...
[Closed] Gear ratios; rear cassette cog options
Probably been asked before but I am looking at options for 10sp rear cassettes; 11-32/11-34/11-36.
As a girl I confess that I occasionally appreciate the 34 and 36 rings (I'm always behind him, so he doesn't know).
But is there any advantage to man up and get the 11-32? Is it just about less of a jump between cog sizes?
Thanks.
Posted : 11/07/2014 7:57 am
Yes, just smoother up and down the range. If you need the bail-out occasionally I'd see that as a bigger advantage.
Posted : 11/07/2014 8:05 am
Unless you are racing I'd always pick the largest total range over smaller steps, it'll keep you moving comfortably more of the time.
Posted : 11/07/2014 8:39 am
11-40 with ratio expander it's top banana
Posted : 11/07/2014 8:49 am
Even for racing I'd choose the widest possible range!
Posted : 11/07/2014 8:54 am
