I was looking to mount my Garmin edge on the top tube of my Rallon. The tubes are too thick to mount with the supplied bands and it seems a bit unsatisfactory. You can get a mount that fits on the knock block for Treks but I was thinking a female mount with an adhesive pad. I could have sworn I'd seen one before but can't find anything on looking at the moment.
Has anyone come across anything like this?
I have one of those ^ and would highly recommend. For some reason you can only twist one way but I have nearly got used to that😀
That's the puppy it didn't come up in searches but that should do the job just fine.
Get longer bands?
Just make sure you can rotate the bars and brake levers if it doesn't clear then you will end up ripping it off in the first crash.
Get longer bands?
Doesn’t always work depending on the frame. E.g.I’d have to wrap them round both the top and down tubes to try and make that work
